Time for a beer. :)
Thanks again to both you and Spuggy for your help on this one :) Ant. |
:cool: you got it working Ant! |
:) :cool:
But if one side/terminal were fixed in the package, then it could matter a lot - any magnet action would be moving the mobile side further away from the fixed terminal if it was inverted... Fingers crossed it's that easy! |
You have to swipe the magnet close to the rear of the sensor while watching your ohm meter response, its a bit fiddly to get the right orientation of the magnet, but if the sensor is ok, you will get the switch to make or break with a good strong magnet.
Ant. Quote:
UPDATE. Bought a second sensor. Tested on bench with positive results. Installed and it works!!! Bad new sensor. Thank you all for the feedback and the help. Side note helps to have a lift as the swap becomes a 10 minute job !!!
Good to hear you got it sorted! Ant. Quote:
| All times are GMT -8. The time now is 07:02 AM. |
