Early 911 Trunk Cover Paint Recommendation
My '71 cardboard trunk cover needs a crack repair and a black re-paint. Any recommendations on what paint to use?
Thanks!
Old 05-08-2025, 11:33 AM
I tried to paint mine due to damage and discoloration from brake fluid and age.
Sprayed rattle can satin black lacquer and it cam out blotchy figuring the quick dry lacquer would not absorb like oil based enamels.
Took some prep, carefully clean and sand then used flat black primer. Resprayed with satin black lacquer topcoat rather than a slow dry oil based Rustoleum. Came out decent considering it’s just thick cardboard.
You need to address the crack, maybe some epoxy or fiberglass mesh on the back side, skim a little epoxy on the front and feather it out.
Personally I’d like to try and steam form and curve a piece of tiger curly maple veneer plywood, stain and clear coat to a furniture finish to replace that wavy cardboard shield.
Old 05-08-2025, 12:26 PM
Great comments. Thanks!
Old 05-08-2025, 01:08 PM
In the right car that could look very cool.
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 05-08-2025, 05:26 PM
Uncertifiable!!!
Uwon's Avatar
How about gluing thick vinyl and wrap it around the edges.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 05-09-2025, 05:07 AM
Just to clarify, your flat black primer was enamel? (I haven't painted anything in awhile so consider myself a newbie.) Thanks!
Old 05-13-2025, 10:20 AM
Yes B_EI, use an enamel (oil based) flat black rattle can.
Avoid a heavy primer coat, just a mist or flash spray to seal the cardboard and the.edges (where it will absorb to most) to seal whatever that old factory finish is, scuff very, very lightly maybe a 400 grit. You can prime this 2-3 times for a uniform surface - and it’s important to allow coats to completely overnight dry each time, watch for any blotches where paint was absorbed and spot prime those areas again if needed.
Reminder- You can use lacquer over enamel base but not enamel over lacquer base coat,
Why I used lacquer - simply for the ease of application, no runs and fast drying time for subsequent coats (2-3).
But enamel top coat would work too, but you have to remember that too heavy paint could run, chip or crack. Lacquer goes on thinner, kind of corrects and evens itself, but may need more light coats.
The basic problem is that shield is just thick paper and edges being most fragile and flexible.
Good luck, post Before and After photos !
Old 05-14-2025, 09:01 AM
PCA Member since 1988
Same as EC900 said, but I used satin black, which seemed to be a better match to the original finish.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 05-15-2025, 12:30 PM
