-   -   911 3.2 head temp sensor pin location (http://forums.pelicanparts.com/porsche-911-technical-forum/1177924-911-3-2-head-temp-sensor-pin-location.html)
jsfried18 05-17-2025 03:42 PM
I removed tech connector for the head temp sensor as it needed to be replaced and forgot to note the pin location. Does anybody know if ground is the top or bottom pin?
john walker's workshop 05-17-2025 08:21 PM
The old one grounded through the sensor to the head. The two wire sensors don't, so it shouldn't matter.
jsfried18 05-18-2025 12:28 PM
Mine is a 2 pin connector. One being ground the other I assume is signal. Are you saying it doesn’t matter what pin goes to what?
wazzz 05-18-2025 12:35 PM
Its a NTC, a kind of resistor. It has no polarity so it doesn't matter which way it is connected.
john walker's workshop 05-18-2025 02:30 PM
Pretty much like a light bulb. Works regardless of polarity.
