-   -   Help identifying a hose I need please.. :) (http://forums.pelicanparts.com/porsche-911-technical-forum/1178085-help-identifying-hose-i-need-please.html)
damiarosyrn 911 05-21-2025 01:20 PM
Hello everyone ......Im hoping I could ask a small question here so I can identify a hose I cant seem to correctly categorize....Ive been chasing a problem and probably a vacuum related but I found this hose was not even connected when I put the cis system back together....I need a new one it does have a cut in it making it questionable anyway...but.....:::
this hose connects to the center port that lays in the back of the engine in the very middle and on the top...the hose then loops around the passenger side and connects to the oil tank, it is one of two pieces. The hose connects to the bottom port on the oil tank.....Sorry for the vague descriptions.
Damian
damiarosyrn 911 05-21-2025 01:42 PM
vehicle: 1983 911sc...3.0
porschyard 05-21-2025 03:46 PM
On an 83 SC the hose assy that attaches to the lower port is the crank case vent hose and on 80-83 they are 2 piece. The hose in the back is 930 107 394 10
and the hose at the tank is 930 107 394 09.
If you have PET go to 83 SC Illustration 104-00 Position # 35A and 35B
Richard
yelcab1 05-21-2025 04:02 PM
Here you go. Line 35 or 35A, and 35Bhttp://forums.pelicanparts.com/uploa...1747868540.jpg
damiarosyrn 911 05-21-2025 05:25 PM
Thank u!!!....looks like 35a...but mine has more curves to it ..maybe the pics aren't perfect either.
Do you think our host has this hose?
Do you know what category this falls into I'd like to see where it hooks up to on the engine side
yelcab1 05-22-2025 06:56 AM
It's been many years since an SC lived in my garage... I believe this is where it goes
http://forums.pelicanparts.com/uploa...1747922197.jpg
Flat6pac 05-22-2025 07:52 AM
If you order the Carrera hose, it’s one piece and will trim to fit at the intake. Both SC and Carrera have air restrictors called for in the hose so the motor doesn’t stall when opening the oil cap. Your old one is sufficient, install it too.
930 207 385 01
Bruce
damiarosyrn 911 05-22-2025 08:55 AM
Thanks for responses....this is the 1 of 2 hoses which goes down to the engine base- intake in the center and attaches to a bracket with a port. Once again sorry for the vague descriptions, i cant find either the intake bracket or hose in the parts diagrams...I have found the correct diagram yet...
Damianh
stevie 77 930 05-22-2025 09:47 AM
oil breather hoses
http://forums.pelicanparts.com/uploa...1747931666.jpghttp://forums.pelicanparts.com/uploa...1747931887.jpg
Here is a view of the 2 hoses:
Top hose vents for the top of the oil tank to CIS boot part # 930.107.399.00
Bottom hose vents from the engine to the oil tank lower fitting
This hose is part of a 2 piece section as already discussed
Part shown in my pic is 35A # 930 107.394 10
the additional hose is part 35B # 930.107.394.09 (not shown in this pic, but connects to oil tank)
the connector is part 35C # 930.110.267.04
damiarosyrn 911 05-22-2025 10:29 AM
Yes thank you all ... I searched that first part number and it looks quite different than in the picture schematic ...thank you
damiarosyrn 911 05-22-2025 10:30 AM
I know this is dumb question but you guys know.... If this hose bus or is just totally not connected will it cause the engine to run different or is it just a breather for the oil tank?
proporsche 05-22-2025 11:51 AM
also make sure you will have the air restrictor in it part number 93010728900-
Ivan
PeteKz 05-22-2025 03:40 PM
It is a breather for the oil tank. However, on the SC, it plugs into the rubber boot on top of the CIS, so you must plug the hole in that boot, or the engine will run poorly. Alternatively, you can run the breather hose from the oil filler neck to a fitting on the airbox on the right side that was originally used for the breather hose on the early CIS models. That is upstream from the air metering unit, so it will not affect engine running.
damiarosyrn 911 05-25-2025 07:44 PM
Thank u Stevie , Richard and everyone!!!
Exactly wat I needed... everyone here is so helpful...
Damian
