				New Fuel Pump Issues
			Hi Everyone
				Looking to get input on a hot start issue I’m having. Drained the fuel tank and replaced the fuel pump on my 1983 911SC last weekend. Today I put a few gallons of gas in so that I could drive to the gas station and fill it up. Car was backfiring a bit on the way to the station due to the low fuel, but ran smoothly after filling up the tank. On the way home the car stalled while idling at a red light and won’t start anymore. The engine is turning over but I’m not getting combustion. Any thoughts on what the issue is?  |
			Have you checked the strainer in the tank? It’s possible you dredged up something from the bottom of the tank and the fuel supply is obstructed at either the strainer or the filter.
			When I replaced my pump, I did not need to drain the tank - I clamped off the supply line and left a bowl under it to catch anything that made it through. This worked well and only maybe half a cup made it into the bowl.
	'80 SC Targa Avondale, Chicago, IL  |
			Good point. I was thinking something might have gotten caught in the fuel injectors but I could first look at the strainer. There’s no way to check the strainer without emptying the 20 gallons of fuel I just put in, right?
			Did you use a Bosch pump? If so it may have failed.  That said, lots of great advice above that is all true and things to check.  The strainer/filter in tank, and the tank itself can be an issue.
			But, the Bosch fuel pumps from the last 5 years are garbage. Lost count of how many warranty ones we needed to replace.... 4 of the warranty replacement pumps were installs with a NEW tank installed as well. Cheers
	Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3  |
 I would check the tank, make sure no debris is getting into the pump. Then make a choice on the pump. Cheers
			What’s the alternative to a new Bosch fuel pump?
	Would it make sense to put a fuel filter between the tank and fuel pump, to catch debris early?  |
			That’s what the strainer is for. And the pump is located immediately downstream of (and next to) the tank, so there isn’t really any room for anything else in-line.
			The Bosch pumps do not fail from debris any more that any other pump would.  They fail from being ****ty.  SC/Carrera pump or even the 930 pump.  The last one we just replaced a week ago was a 930 pump in a 3.2 Carrera we converted to a custom turbo set up.  New fuel tank 18 months ago......
			We are still searching for a better more reliable replacement. As this warranty stuff in annoying. Ya, we get a new pump for free, and we get paid a very small percentage of our labor to replace it. But its a waste of time for our clients and it still costs us money as the lifts and manpower could be used doing profitable jobs. Same goes for any Bosch Reman part, be it a starter or an alternator. Stay away from it. As a DIY guy you are better off sourcing a local business that can rebuild it. Every city has multiple shops and every small town has at least one shop that can do the job. Cheers
 If you make a jumper with a switch, you can test pressure and flow with the engine static. How to: https://forums.pelicanparts.com/porsche-911-technical-forum/1132263-fuel-pump-relay-bypass.html Last edited by porschedude996; 05-20-2025 at 08:13 AM..  |
			Update for everyone. I pulled the fuel tank drain plug and that looked fine. I also tested fuel line going into the fuel accumulator and I was seeing fuel, so the fuel pump seems fine. Any other thoughts? Should I test the line going into the fuel distributor?
			You could check the fuel pump delivery rate at the return line to the tank.  It should flow 1,000 cc in 30 seconds.
	Ed 1973.5 T  |
			Going back to the original post, I don't think low fuel should cause the car to backfire.  It is something else.  Are you sure you have spark?
			Pull an injector (any injector), put it in a jar and with the pump energized, lift the metering plate in the air box. Is there fuel spraying out of the injector? Don't do this for long, if there is fuel the other injectors are dumping fuel into the cylinders. After that, it's time to check if you have spark. Mark
	1979 911SC Targa  |
			I can confirm I’ve got spark and the fuel injectors are spraying fuel. Am I correct in assuming it’s most likely a timing issue?
			 PCA Member since 1988
			No.  Incorrect timing would cause poor running, but not no-start.
					Go back to basics: Compression, fuel, spark. Your compression is probably okay, but I would check it anyway to rule it out. Then fuel: Jumper the pump so it runs when you turn on the ignition. Then remove the air filter and stick your finger up in the air metering unit and raise the arm. You should hear the injectors squeak. Only do this for a couple seconds, or you will flood the engine. If you have compression and fuel, then it's loss of spark. Recheck everything. Based on your description so far, I think you are losing spark. It may be a problem when the car warms up and the ignition coil or CDI box get warm. See if the car fires when it is cold. It may be possible that you flooded the engine during your starting attempts, and that's why it won't start. If you haven't done the compression test, then remove all the spark plugs and crank the engine through about 10 cycles. That should clear the flooding too. If flooded, that may be due to a stuck cold start valve or something related.
			1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 05-24-2025 at 03:23 PM..  |
