Overdrive pulley for Clewett belt drive
So I put the Clewett belt drive on my car but I didn't think the underdrive pulley would be an issue. However, it's proving to be a problem at idle when I have the AC on.
Does anyone know if there's an overdrive or standard ratio pulley I can get?
1978 911SC with Lobster Interior - Zoidberg
http://forums.pelicanparts.com/porsche-911-technical-forum/1126971-zoidberg-my-1978-911sc.html
Old 06-26-2025, 05:51 PM
V Belt drive
The Adaptmotorsport v-belt drive is a standard ratio. It drives the alternator at the same speed and my electric AC works just the same.
Try contacting them to see if you can just order just the parts you need.
'82 SC non-original...with '86 Carrera interior...aero mirrors...968 roof antenna...JWest shifter...CR eletrocooler, alternator and fuse panel...RHD/Xfaktory ITBs...Bosch cops...EMU Black ecu...Adapt Motorsports crank/cam sensor, crank pulley...M1 cams...Achtungkraft GTK exhaust
https://www.instagram.com/mango_911sc/
Old 06-26-2025, 09:35 PM
