Cevan's Avatar
Sunroof fail - quick question
Driving home yesterday and the sunroof failed. The right side moves forward but the left side appears stuck. It's currently open about 4 inches. I've just started down the rabbit hole of threads here about sunroof repairs and 964 cables , etc.
I am wondering if I can just get it fully closed so I can use the car until winter and then fix it. It appears that in it's current state with the roof open a little, I can access the clips holding the roofliner in place and I could unclip them and move the liner back before trying to get the panel fully closed.
I do not want to close it and then have a problem in the winter trying to disassemble the roof to repair it.
Thoughts?
1986 Carrera coupe - black on black
1972 CB500/4
Old 05-28-2025, 09:26 AM
Unzip the rear flap in the headliner. Remove the lefthand panel (couple of phillips head screws). then remove the gearbox (two phillips screws) - it just lifts out.
Once the gearbox is out the cables are free to move and you should be able to get the sunroof back into position.
Sounds like one of the cables probably broke, pretty common and not hard to fix.
Old 05-28-2025, 09:43 AM
Cevan's Avatar
Thanks for the help. This worked. I also needed to pop the seven clips holding the interior panel to the sunroof and slide it back into the roof in order to push the panel all the way forward. Used some closed cell foam to wedge the rear of the panel upwards and flush with the roof.
1972 CB500/4
Old 05-30-2025, 05:52 PM
Still here
pmax's Avatar
Take any pics ?
Old 05-30-2025, 06:15 PM
Cevan's Avatar
Transmission
1972 CB500/4
Old 05-31-2025, 04:07 AM
