-   -   where does this a/c clutch wire connect to? (http://forums.pelicanparts.com/porsche-911-technical-forum/1178721-where-does-c-clutch-wire-connect.html)
mo-mon 06-07-2025 03:56 AM
1988 carrera. I had to move the a/c compessor.out of the way & when I put it back, this wire came.loose. Does anyone know where it connects to?
I know that this wire activates the a/c clutch but I can't seem to find its attachment. Pls help. TIAhttp://forums.pelicanparts.com/uploa...1749293784.jpg
proporsche 06-07-2025 05:03 AM
right hand side is your other connector
Ivan
porschedude996 06-07-2025 06:11 AM
Stretch out the cable to the right and the mate should be somewhere under the Oil Filter.
GH85Carrera 06-07-2025 06:44 AM
This. You compressor clutch will never engage with out it connected. No AC that way.
mo-mon 06-07-2025 06:10 PM
Found where it mated to. Thank you gentlemen.
