Speaker repair
Wanting to keep the '88 as original as possible, I sent the Blaupunkt Reno out for repairs and a checkup. The other half of the system (speakers) weren't sounding so good, so I pulled the grills to find the foam speaker surrounds were about 50% disintegrated. They crumbled at the slightest touch.
These blaupunkt speakers used a foam acoustic suspension system which acts as a supporting bridge between the paper speaker cone and the frame. Over time, these things simply fall apart.
Speakers aren't all that expensive to replace, but I decided to repair the originals as the coils were still good. Blaupunkt speakers for a Blaupunkt stereo, right? Apparently, this is a problem for lots of people as there are companies out there who repair speakers and also sell a re-foam kit for do-it- yourselfers. Cost runs about $7-8 per foam surround. I bought mine from Speakerworks. They provide the glue, instructions and an online how to video. Reinstalled the speakers last night: they sound great.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 03-09-2016, 06:43 AM
wrxnofx's Avatar
Wow, awesome! Any pics of the process?
Also, how do you get the speaker covers off? Do they just pull off? My front grills are cracked around the perimeter, so I'm totally scared to start prying on them...
1987 911 Carrera coupe - Guards Red
2010 997.2 C4S 6-Speed
2005 Mini Cooper Convertible (R52) - Wife's car
1977 VW Bay Window Camper Bus
Old 03-09-2016, 07:25 AM
No need for pix when the Speakerworks.com people show you how with an online video. Pretty simple. Trick is to get the right ones & they seem to have all kinds in stock. Have to get ones that have the angled edge (to glue to the cone) vs a flat edge if that's what your speaker calls for. Their diagram explains it.
The grill just pops off. I thought they may screw on, but no. Perhaps un-screwing motion will help loosen it if it appears stuck. No tools necessary to pop off the covers.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 03-09-2016, 08:16 AM
If not at ease with diy...there are many small shops that repair speakers. I had a pr of Bose 501's that were not sounding like they should. Pulled the fabric cover off..the foam surrounds had all fallen out. Brought them in to a local repair shop...$25ea and they were like brand new again.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 03-09-2016, 09:12 AM
The video: Speaker Repair Video
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 03-09-2016, 10:23 AM
Nice job, jlex do mine sharing which kit numbers.
Now I am glad I kept my original speakers.
Which like yours were disintegrated when bought my car.
Old 03-09-2016, 11:59 AM
I'll look up the order numbers and get back to you. The round door speaker kits were an easy find on the web site, but the 4" x 6" repair kits for the rear speakers weren't listed. The guy from the store had to send me a link for the correct application.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 03-09-2016, 12:41 PM
Here you go:
the two 5" door speakers were SWK5 @ 6.95 each
the two 4" x 6" rear speakers were SWK46A @ 9.94 each.
Add 1 order of the better adhesive for $1.99. The one bottle should be enough to do all four unless you're sloppy and really load it on.
As I said, these fit the original Blaupunkt speakers from my '88 Carrera.
Before you order, you should take the speakers out & measure them to make sure.
If the paper cone is torn, you may opt for a more extensive repair or replacement.
Fun job
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 03-09-2016, 12:55 PM
Thanks! jlex
Best Wishes.
Old 03-09-2016, 01:00 PM
Just something so satisfying about fixing something rather than tossing and buying a new one.
Nice work!
Rutager West
Old 03-09-2016, 01:34 PM
Fleabit peanut monkey
Bob Kontak's Avatar
DIY is simple but labor intensive. Small car speakers, some beer and a couple of hours. About right, jlex?
I acquired a set of Series I Bose 901's with the Equalizer in exchange for working on an old Alfa for a day. About 20 speakers in total. I am afraid to open them up.
1981 911SC Targa
Old 03-09-2016, 03:08 PM
Absolutely beats repacking greasy CV joints
Nice clean winter project if you're stuck inside. Replacement speakers aren't too expensive unless you want to go crazy. What I found is nearly all replacement speakers are rated 4 ohm whereas the Blaupunkts are marked 8 ohm. Read somewhere it may negatively impact the amplifier, so I'm motivated to preserve the original radio and besides.... I'm cheap
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 03-09-2016, 05:22 PM
Bob Kontak's Avatar
Tight as a crabs ass.....but wise.
1981 911SC Targa
Old 03-09-2016, 06:59 PM
Recreational User
porschenut's Avatar
18 drivers IIRC. I had 2 pairs back in the day. Each cabinet has 8 firing backwards and one facing forward as I remember it.
Old 03-10-2016, 06:35 AM
sky1jord's Avatar
Just did this with one of my door-mounted midrange speakers about a month ago. Too bad I didn't know about this supplier, I used simplyspeakers.com, more expensive but theirs worked out fine.
Things I learned: Glue the new foam to the cone FIRST and let it completely dry (overnight) , then glue the new foam to the frame.
My speaker covers just snapped off, I was VERY careful. (and maybe lucky)
Old 03-10-2016, 10:58 AM
Yeah, it's definitely a two-stage gluing process. You also have to pay attention to how the cone is positioned before doing the final gluing to the frame. If the cone/surround is glued to the frame off kilter, the magnet will rub against the coil while in operation and produce a scratchy noise. When you do the second stage final gluing to the frame, gently push up and down on the cone while gluing to make sure it's centered and you hear no scratching while doing so. Easy mistake to make.
Looks like they linked our discussion to Facebook. Can see here for more speaker eye candy: https://www.facebook.com/speakerworkscom
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 03-10-2016, 11:38 AM
[U]Speaker repair means finding the problem when a speaker is not working properly. For example, if the sound is broken, there is no sound coming out, or there is a muffled sound, then the driver or wiring may be bad. Using a tool like fix my speaker, you can easily identify the problems and repair them. With proper care, the speaker will stay in good condition and produce clear, beautiful sound.
Old 06-09-2025, 02:17 AM
(man/dude)
Jonny042's Avatar
Originally Posted by rwest View Post
just something so satisfying about fixing something rather than tossing and buying a new one.
Nice work!
+1!
Heavy Metal! Part Deux - The Carbon Copy
Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD)
85 Coupe - The Rot Rod! AX beater
Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911
Old 06-09-2025, 07:29 AM
Miyareddy has been reported to the Mods.
Rutager West
Old 06-09-2025, 07:25 PM
