Drive it like u stole it.
Electric A/C (Not Classic Retrofit) options
So a video popped up in my YouTube feed of a very inexpensive electric A/C option for classic cars (it even includes heat!). The entire under dash system was under $600. This did not include an alternator (that was needed) but basically everything else. The same company offers a similar system with an air box with 4 ports to use behind the dash. The main issue I see is the size of the condenser (14" X 18"). As I was interested in a behind the fender mount, this may be restrictive. The more I investigated though, I found a 12V compressor for $400. The question is, what would it take to adapt some of this stuff. The kit would be simple if you could find a place for the condenser I suppose and then connect up the ducts.
Here is a link to the kit: Amazon AC Kit What are our options for Alternators to run these besides Classic Retrofits?
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ Last edited by jonesb930; 06-11-2025 at 07:59 AM.. |
The 9 Store
Condensers are cheap. So are the electric fans that fit on them.
All used parts sold as is. |
Here is a write up on my hybrid AC system:
https://forums.pelicanparts.com/porsche-911-technical-forum/1144750-1985-ac-project.html In it I have a cost roll up sheet. You will see that I used some of the CR components and some of the Griffiths. You could see the value of substituting some of those parts. I went with a fender condenser and an under the chin condenser. It works great in Southern California...not sure how it would do in higher humidity locations. One of the main benefits to the CR system, in my opinion, is the ECU controlling it and managing/protecting it and the car's electrical system. Without it, you have to manage it. All that being said, give it a go! It could be a fun project. |
Our system works because of the power management software in the ECU. Without this, when the engine idles, the battery voltage sags and the compressor goes into a fault mode. There is no way you will fit any off the shelf evaporator/blower 'behind the dash' - unless you don't mind it invading the luggage bay and looking like a dog's breakfast. Regarding the alternator, I will save you the bother of all the 'just rewind the stator' answers. Our journey started with that approach almost ten years ago. We tried 'rewinds' of the Carrera 3.2 unit for 110A and 130A. Although they all produced the required power, the triumph was short lived. In every case, the insulation overheated, causing the windings to short out. I set fire to 3 alternators and almost torched my car in the process! It is no fun trying to remove a smoldering alternator from a 911 in a hurry. The issue is that the standard alternator does not have an internal fan so it cannot dissipate the heat from the extra windings. And no, the engine fan on a 911 does not cool the alternator, in fact it is a hinderance as the alternator is trapped inside it. Good luck!
www.classicretrofit.com |
Bill,
FWIW I run a single 12 x12 generic condenser in the LF fender. With good air flow, it's enough for plenty of cold air. I have it ducted from the brake duct in the spoiler with a 12" puller fan behind it. I'm still running an engine driven compressor. I have cold AC, but it would be nice to get some weight off the rear. I have the CR alternator, puts out good clean voltage at idle.
Rick 1978 911SC |
____________________________ Bill Jones Jupiter, FL 77 Euro 911 3.0 Wide Body - under construction http://www.flickr.com/photos/rennsport/collections/72157618856489537/ |
If I took this approach, what components could be installed and used along the way other than the alternator? Any improvements you recommend while it's all apart? Bill
Still here
Not sure how long that would last given the rpms but hey, it's a project. |
Rick 1978 911SC |
![]() ![]() ![]() My bumper solution is a modified 934 bumper. After running this system behind a IROC bumper with the coolers in the fenders, and no airflow from vents (system worked fine in Florida) I went to this look. I don't think the system will cool better because of the airflow over the condensers when the car is moving (like on the freeway) because the fans do a pretty good job. Before the systems was great. I wont know for sure for a few more weeks, when I finally get her back on the road.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
