GT-Racing Ducktail Fitment
Hello,
Has anyone bought and used a ducktail from GT-Racing? Planning to buy one used, and wanted to see what everyone’s experience is like with this product? anything I need to look out for? Thanks! ![]() ![]()
Porsche Owner
if its already been fitted to a 911, it's less work. if it's raw, it's more work. that's the story with all fiberglass parts. i've contemplated many years with which ducktail to use. decided to pull the trigger on a stratton and that was garbage too. i ended up with a pre-fitted getty. so, you might as well give it a go and have your body guy help with making it look as good as possible.
1987 Carrera - 2008 Cayenne Turbo |
(man/dude)
That doesn't look like it is even remotely shaped like a factory decklid at the trailing edge.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
anything GT racing I have tried fits like absolute garbage. Be ready to put in some fiberglass work to make it fit properly.
I ended up passing on it. Thanks for the input.
Any other suggestions? |
Registered Minimalist
Getty is decent, but all 'glass requires work to get good fitment.
Sonjay in the classified will take your metal stock decklid and put a duck on it for best fit. There are also aftermarket aluminum ducks. I have one and the fit is stellar, but bring extra cash.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
Full Send Society
ST-parts makes some amazing glass parts that look and fit phenomenally (but cost accordingly) and even those require lots of fine tuning.
-Julian 1977 911 S: Backdate, EFI/ITB, AC project in the works: http://forums.pelicanparts.com/porsche-911-technical-forum/1106768-when-well-enough-cant-left-alone-backdate-efi-itb-ac-more.html |
Now in Florida !
Location: York Beach, Maine and Anastasia Island, Florida
Julian,
You've mentioned ST-parts in the past also. I've searched for them with no luck. Any chance that you can pass along contact or web site info? Tom
1983 911SC Coupe Hot Rod - Platinum - Twin plugged 3.4, DC-60 cams, PMO 50's, 1 3/4 headers, Bill Rader 915 w/LSD 1976 914 2.0 Lime Green Metallic - Completely stock |
Anyone try this one? All aftermarket fiberglass ducktail need to be fitted anyways. Wouldn’t this make sense because of the price? |
