bose213's Avatar
Fuel pressure
Hey everyone, I’m having an issue with my car jerking at over 4000 RPM. 911sc 1979
I decided to check the fuel system pressure. The control pressure, system pressure, and leak test all showed factory-spec values. However, I noticed something strange: when I closed the valve on the gauge to check system pressure, the pressure went up to 5 bar as it should. But when I opened the valve again to check control pressure, the pressure stayed at 5 bar and didn’t drop as expected.
Sometimes the pressure would go back down to normal, but other times it just got stuck at 5 bar. So clearly, something’s not right.
Where should I start looking to find the root of this problem?
Here’s a video where it’s all shown clearly:
http://youtu.be/2qVKN8Gk02M?si=8k7_uk7zEflI9wqF
Also there is bubbles in the fuel tank, is it okay? Video:
https://youtube.com/shorts/T8IoXqjbWKE?si=nKHJSfC-niXcvmJV
Arthur.
Owns a Porsche 911sc 1979 Sportomatic.
Old 06-24-2025, 04:40 AM
A few weeks back at least two members found their fuel pressure gauge to be acting up.
I can't find the posts... sorry.
Found one, but there are more recent ones, I'll look again:
https://forums.pelicanparts.com/porsche-911-technical-forum/838021-harbor-freight-cis-fuel-pressure-tester-review-2.html
81 SC.
930/16 (us model)
Old 06-24-2025, 04:44 AM
bose213's Avatar
Thank you very much!
Arthur.
Old 06-24-2025, 05:35 AM
No Problem.
Found the recent post I was thinking about:
https://forums.pelicanparts.com/porsche-911-technical-forum/1174439-cis-control-system-control-pressure-question.html
81 SC.
930/16 (us model)
Old 06-24-2025, 05:39 AM
