Another what is this wire thread
http://forums.pelicanparts.com/uploa...1749950702.jpg
http://forums.pelicanparts.com/uploa...1749950702.jpg The car is an RS clone using a '69 912 tub with a 3.2 |
It looks a bit like the connector that joins up the wiring for the tail light/indicator/brake light. It's been a while but I'm sure there is one like that in there.
Relay base. Likely not used after the conversion.
Maybe the idle speed test pug.
Yes this is the idle speed test socket !
Thank you from the Netherlands. Now help me understand what it does.
| All times are GMT -8. The time now is 10:04 AM. |
