1979 SC Stereo Speakers Blown/Replace
What are the suggested option for replacing the speakers similar to OEM ones on a 79SC...I dont listen to the radio much, but at least some decent speakers would be good. Thanks All-
1979 911SC 1988 911 RoW Japan Outlaw 2018 BMW M240ix |
Just about any aftermarket 2-way door speaker (only - no rears) will work fine but the problem might be in the install and matching the mounting holes. Don’t recall the size 5 -6”, but be mindful of the depth too. Some good replacements can be had at Crutchfield for $100-$150 pair or even less for JBL, Kicker and Pioneer stuff is reliable for sound, nothing spectacular or over the top performance. They have a “does it fit” assist drop-down.
I was in the same boat, not much into the radio but just enough to add some chatter to the miles. For what it’s worth I found my aftermarket Pioneers (doors only option) hacked in, loose, knocking about held hanging on two sheet metal screws, broken wire splices, baffle covers missing and no plastic rain sheeting surely had some affect on the speaker itself. So check the condition of your originals they may be salvageable if it matters. If the wires were crossed, it could cause the sound to be affected and seem blown-out. Once you have the size and depth, hole pattern might be useful but I was able to use fender washers to extend and cover a couple of gaps. Also worth a note; keeping my original speaker grilles required some JB Weld to repair the broken studs when the prior installer tried to pry them off - which isn’t possible, there are one way retainers on the inside door cards. |
Been here a while
5 1/4" fit into the factory rear covers/rain shields, assuming the ones you choose aren't too deep.
6 1/2" fit without the rain covers, best to protect the back side of the speaker with some plastic sheeting extended from the moisture barrier on the inner door panel. plan on a new moisture barrier anyway.
looking for 1972 911t motor XR584, S/N 6121622 |
Any ideas for the rear shelf speakers? Finding the correct size (depth included) is not easy. The ones here on Pelican do not fit, despite what the site says. Ugh.
I have one blown original blaupunkt 8 ohm. 1979 911 SC |
Call Crutchfield . . ask for tech support . tell them what car you have and they can guide you to what will fit.
https://forums.pelicanparts.com/porsche-911-technical-forum/1112559-new-rear-shelf-replacement-speakers.html Mark
1979 911SC Targa Last edited by Mark Salvetti; 05-31-2025 at 10:17 AM.. |
PCA Member since 1988
Crutchfeiuld publishes detailed dimensions of the speakers, so you can match the speakers you have now, or find some that will fit in the hole.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Thanks for the great info and Link. I think I will just replace the fronts, which dont even work at this point. The rears are shot but will just disconnect. My head unit on the car when I bought is a Kenwood, at least 15 years old..lol
Front speakers: I wrote about them here + have a set of instructions & photos: https://forums.pelicanparts.com/porsche-911-technical-forum/1159035-installing-carbone-rs-door-cards.html#post12214876
Short version: * get 6.5” and do away with the shallow and restrictive 4.5” plastic bafffles * foam baffles will keep water off the rear of the speaker * use washers to help insulate the fasteners and the door to improve sound quality * I used Infinity Reference 6532ex’s (https://www.crutchfield.com/p_108R6532EM/Infinity-Reference-REF-6532ex.html) - anything with same dimensions will work. You have a bit of room for play with depth-wise when you remove the OE plastic baffles. * Mine are flush with the door cards (no grilles; just perforated cards), which is also why I chose that model (shallow front depth).
1978 911 SC (3.2SS, EFI, 993SS cams + the trimmings) Dynamic CR calculator: https://dcr.questionable.services/ Gear Ratio (Speed @ RPM) calc: https://ratio.questionable.services/ |
