LinkBack | Thread Tools | Rate Thread |
greg79s
Rear Bearing Replacement without removing Swingarm on 930 Turbo/Option 491 cars
Hello. I recently serviced the wheel bearings my 3.2 (Option 491) car. The right inner bearing failed last year and I was successful replacing the inner bearing without removing the swingarm. This project now is the left side where the left inner bearing is being replaced. The tools utilized (these tools kits worked for this project) will be a correct size slide hammer (SPX #6540 and a KD tools #41630 Bearing Race and Seal Kit. I purchased some hardware (5/8 " grade 8 bolt and nut with washers to use bearing race kit as a puller. (3) 14 mm X 1.50 thread pitch nuts with washers were used to attach slide hammer to hub.
greg79s
930 Swingarm Wheel Bearing Replacement Part 1
Disconnect brake caliper and move it aside, remove rotor, half shaft, and bolt from hub. Install slide hammer to lugs and install 14 mm X 1.5 bolts and washers. Give it several impacts and it you will notice the assembly slowly extracting from the hub. When the assembly is removed clean it up and set aside.
greg79s
930 Rear Bearing Replacement Part 1
Remove inner bearing seal and bearing on swingarm (pry seal out with seal puller. To remove the inner bearing race from the swingarm, the 2.555 dish from the puller kit catches the edge on the race perfectly so it can be pushed out (notice the dish is inverted) Strike with hammer and the race will start moving evenly out.
The emergency brake is being serviced now and some cleaning will be done. The installation on the new bearing, seal and assembly will be posted in part 2. Hope you can use the information. ![]()
Forced Induction Junkie
Whatever happened to Part 2?
Dave '85 930 Factory Special Wishes Flachbau Werk I Zuffenhausen 3.3l/330BHP Engine with Sonderwunsch Cams, FabSpeed Headers, Kokeln IC, Twin Plugged Electromotive Crankfire, Tial Wastegate(0.8 Bar), K27 Hybrid Turbo, Ruf Twin-tip Muffler, Fikse FM-5's 8&10x17, 8:41 R&P |
Part #2........
He's still trying to remove it!!!!! Just kidding. Like to see the pictures for part #2. This post is very helpful and I have those puller set and never had the chance to use them due to my 10-ton HF press. The information and use of the right tools would be helpful to others to follow. Good post. Tony |
greg79s
Bump
greg79s
Greg, if you are still on the forum, thanks for posting this. I hear a highly suspicious racket in my right rear hub, so I’m tackling this project on this 84 M491.
If anyone else has some helpful hints, I would definitely appreciate them. Thanks, Jeff
is this similar to the 930 bearing
From the Turbo / 930 forum we have this well done thread.
https://forums.pelicanparts.com/911-930-turbo-super-charging-forum/870784-another-rear-wheel-bearing-replacement-job.html Best of luck, Rahl
1976 930 turbo Carrera, "Ubich". Mostly stock, lightly sweetened. She’s an angry schwierigkeit. She doesn’t want flowers, she just wants to dance! And when she does, she shakes her hips to the rythem of the road. Drive her like you hate her! |
lots of heat to get the old one out.
check the 930 forum. there is a good thread over there that has some home made tools. the trick I found for setting the play of the crush sleeve is basically to angle torque it. torque it up to about 320. then angle torque it 45 degrees. loosen it then torque back up to I think it is 220 and check the play. if it has not crushed then repeat above torque to 320. but angle torque 90 degrees . (I marked the nut each time). then repeat for checking play. keep repeating the above and increasing the angle until it starts to crush the sleeve. that was what gave me a hard time, determining when the sleeve was crushing, once I figured out this procedure the other side went very fast.
Tighten an additional xx degrees.
toque it to 320
then turn it another 45 degrees. then check the play torque it again to 320 then turn it 90 degrees if you need to keep increasing the angle or number of degrees of additional torque until the crush sleeve crushes. my problem was was trying to figure when the crush sleeve started to crush.
Right now, trying to get the hub out. Thing is really stuck and I’ve read some horrifying threads about this. I may pull the engine and reseal, new clutch, etc. Might be easier to wait on this bearing work until after the engine and transmission are out. While I’ve got you, is this turbo rear wheel bearing design set up so the bearings can’t be cleaned and regreased without all this trauma? The standard Carrera has a sealed bearing so at least those may not need servicing regularly. Maybe I’m looking at this wrong, but it seems a little crazy for the turbo bearings to be so inaccessible to regular maintenance. |
read that thread above,
did you disconnect the parking brake and adjust the shoes down. you need to pull the engine to do this you need lots if heat on the inside of the trailing arm to get the race out. I had 2 propane torches going. I think when we did my brothers we may have had 4. I did mine by myself.
Yes, I am going by the procedure in that excellent thread. Parking brake backed off and rotor loose. Hub won’t budge, but I haven’t given up yet..
Good Luck, Regards, Roy T
2002 Porsche Boxster S Cobalt Blue/Blk/Blk Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine |
Fairview,
You are trying to pull the outer stub shaft out of the inner bearing "inner bearing race", which is an interference fit. You have to keep tension on the slide hammer puller as you strike blows with the slide hammer. You may need someone to assist you if necessary. Or you may need a bigger slide hammer puller. This is only the first step in your journey to wheel bearing replacement. You do not need to remove the engine to do this job. Grease seals are the weak link in this setup. My rear inner bearing failed because the grease seal failed and dirt got into the bearing.
-Dennis 1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R |
