My 81 SC build/Front suspension pan replacement
Hello everyone. I have been on the forums for few years now. I don't post much, I usually browse the for sale section. This post is about my first 911 I ever owned. I bought it June, of 2016. It was a driver but needed a lot of TLC. I began on the engine. I pretty much just did a tune up. Change all the injectors, spark plugs, rubber hoses itc. After a few months I decided I wanted to backdate the exhaust system. During removal, I broke a few exhaust studs. At that point I decided to pull the motor out and do a bunch of "while you were in there stuff". Soon after that my son was born and the project stalled for about 2.5 years. Recently I was able to find time to work on my Porsche. I really want to drive it again. I am not doing a complete restoration, just fixing it up to have a solid driver.
My build starts with the front suspension pan replacement and some other rust issues.
Pic are coming.
Old 09-08-2019, 07:13 PM
Some pictures when I first bought the car.
Old 09-08-2019, 07:27 PM
Some pictures of when I first pulled the motor.
I pulled the motor in 2017 and the project stalled for almost 2 years.
Recently I began the rust repairs.
Old 09-08-2019, 07:39 PM
Old 09-08-2019, 07:50 PM
I found the front clip here on the forums. It is rust free and has everything I need to make my repairs.
Front suspension is out.
Now is the tricky part. It is crucial that the new pans suspension points are in exactly the same location. I have been watching Tom from aghh Garage Time and he has been very inspirational. I decided that in order to insure proper alignment I will build a jig.
Old 09-08-2019, 07:58 PM
Old 09-08-2019, 08:10 PM
Reiver
Reiver's Avatar
Man... I don't think I've ever seen an SC that rusted out.....that's some work there...luck to you...
De Oppresso Liber
Strength and Honor 5th Legion
Old 09-08-2019, 08:34 PM
You can just refit the suspension to check alignment.Restoration design have Ytube video on this.If the front pan is that rusted,I bet youll eventually complete a full body restoration,once you inspect the "usual" places.
Old 09-08-2019, 09:27 PM
I did see that video and I don't agree with that method. There is a chance the pan will be few mil higher or lower and that will throw off the geometry of the suspension.
Old 09-09-2019, 06:37 AM
Made some progress today on the jig build.
Old 09-09-2019, 10:57 AM
Old 09-09-2019, 11:47 AM
Finished up the jig today. Now I can start removing the suspension pan.
https://forums.pelicanparts.com/porsche-911-technical-forum/1039583-my-81-sc-build-front-suspension-pan-replacement.html
IG @stracer902
Old 09-14-2019, 08:27 PM
Great job, stick to it and you and your son can enjoy the car for ever!
Kermit, 73 RS clone,
Just Part of the Team
Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark
Jerry Sherman ,Rob McGlade ,Donnie Deal
Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains
Old 09-15-2019, 05:41 AM
Old Pan is almost completely out.
This area is not part of the Pan, but will definitely have to be replaced with new metal.
IG @stracer902
Old 09-19-2019, 09:52 AM
Made some progress in the last few weeks. I cut all the rust out in the Battery area.
Tacked in new metal.
I also closed off the hole for the condenser blower. I don't plan on using AC.
IG @stracer902
Old 10-13-2019, 02:21 PM
Cool stuff! I like your jig and that front clip was a great score. It doesn't look like you need any extra inspiration to pull this off but Classic Carreras is the website of an excellent restorer in Ireland who documents his work, much of which is shell rebuilds...and in Ireland and GB, 911's rust badly. Best, John/CT
Old 10-13-2019, 04:43 PM
Thanks for the link John. I will definitely check it out. I am very amateur at this and I love learning from other peoples work.
IG @stracer902
Old 10-13-2019, 07:51 PM
Bill Douglas's Avatar
Nicely done work going on there.
Sweet looking SC. I'm pleased for you that you will have an excellent car at the end of it and the personal satisfaction that you have done it yourself.
Old 10-13-2019, 08:05 PM
I still have to fill in 2 holes, but for the most part this piece is welded in.
I have a question for the experienced guys here. At this point, once I finish grinding down the welds of course, is it ok to just spray epoxy primer or should I first apply fiberglass filler over the welds?
IG @stracer902
Old 10-21-2019, 05:48 AM
Great Job on this! Love the jig too.
Regarding the welds, a sandblaster is best prior to epoxy primer. However I wire brush with an angle grinder and then sand with an 80 Grit disc.
There are certainly other opinions out there too.
www.ahhgaragetime.com
Old 10-21-2019, 09:02 AM
