real 2.7 MFI or not ??
Hi all
I need an urgent help : may somebody tell me the parts to check to be sure i'm buying a 2.7 rs MFI engine, the seller gave me numbers that match nothing ?? I know what it looks like but not accurately enough :confused: This is to become a child dream for me the engine 's been rebuilt 10 000kms ago, the man have the papers, but are there numbers anywhere, special parts, identification signs ? is there a noticable difference between a 2.4 MFI and a 2.7 carrera MFI ? and my last question : may you confirm to me the 2.7 RS engines (73) and 2.7 euro carrera (74,75,76) where exactly the same ? I'm waiting for your grateful help Best regards Philippe |
The number on the case should be 911/83 for the '73 and also the Euro '74 and '75 Carrera RS engines.
thanks but
any another precious advice ?
please, please Philippe |
The serial numbers for the '73 RS engines should be 663XXXX. The '74 RS engine should be 664XXXX, and the '75 RS engine would be 665XXXX. There were a limited number of '76 RS engines and those I assume would be 666XXXX. All the RS engines (911/83) are the same no matter what year car it is in. Hope this helps.
nobody for my 2.7 MFI ??
No MFI 2.7 engine specialist on this board ?
They have given you what you need. The numbers tell the story i.e. 911/83. Other than that a 2.7rs and a 2.4s motor look identical.
Re: real 2.7 MFI or not ??
you need: the engine type 911/83 engine serial number 663... 664.... 665.... and the mfi pump type number, i don't have but i can try to find i think those are all the numbers you can get. For anything else, you will have to take things apart. |
73 RS / 74 Euro Carrera MFI pump:
porsche # 911 110 254 00 bosch # 0408 126 019 source: check, measure, adjust |
many thanks
This could be a precious help
I'm going to check the car tomorow regards Philippe |
| All times are GMT -8. The time now is 06:55 AM. |
