Porsche Crest Weber Carb mods??
I have a 1969 911t 2.0 with Weber TIPO 40IDA 301 carbs. I'm rebuilding the carbs and needs some assistance. Can I upgrade to a higher volume choke. Currently it has #30. I'm going to mirror polish each one just in case I can't modify my carbs. What kind of mods do you recommend for this carb?
Old 06-20-2025, 08:51 AM
Hi
Original factory chokes for a 2 liter, 911T engine are 27mm.
Would suggest you don't go any bigger than the 30mm ones you have .
See link below for more info.
Cheers
https://forums.pelicanparts.com/porsche-911-technical-forum/989063-weber-pmo-throttle-venturi-sizing-equations.html
Old 06-20-2025, 04:45 PM
Banned
Absolutely, you can go up in choke size depending on your engine setup and goals. A #30 is on the small side, if you’re running a stock 2.0, something like 32–34mm might give you a bit more top-end without sacrificing too much low-end response. Just be sure to match jets accordingly.
Old 06-21-2025, 01:43 AM
It's a 914 ...
stownsen914's Avatar
Here are some recommendations from PMO on Weber carb setup. I think the ports in a 2.0 T are 30 or 32 mm?
Old 06-21-2025, 07:07 AM
Tags
weber 40 ida 3c , weber 40 ida 3c rebuild
