Czar of C.R.A.P.
dfink's Avatar
Question 85 carrera cabriolet radio wiring
1985 911 carrera cabriolet with blaupunkt radio. The radio will not hold the channel when turned off. There are two wires coming from the bundle. One for the main power and then one with a fuse. Is that one supposed to go the continuous power terminal of the radio as indicated in the radio owners guide. ( I have the guide for the radio but not for the car ) There is also a black wire coming out of the harness with the antenae wire. "sorry for the spelling" There is also a large brown wire which I assume is the ground. All worked fine till I tried to pull the radio to check for a non functional right speaker. The speaker works OK and the radio works OK. I don't have good definition front to rear and the car had a factory AT&T cell phone. I think the problem may be in the cutout for the cell phone. Would I be better off to just rewire all the speakers.
Old 07-07-2003, 06:03 PM
Cool
" bell " usually has all the answers for this stuff ..........Ron
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 07-07-2003, 06:09 PM
ruf-porsche's Avatar
Blaupunkt radio are wired as follow
Yellow goes to 12 volt continuous
Red goes to ignition switch 12 volt
Black is ground
Blue is for power antenna or 12volt turn on switch for power amp
White and White with black stripe are for LF speaker
Gray and Gray with black stripe are for RF speaker
Green and Green with black stripe are for LR speaker
Violet and Violet with black stipe are for RR speaker
Old 07-07-2003, 06:13 PM
one of gods prototypes
bell's Avatar
not sure on the factory cell phone......maybe someone has a schematic on this.
the thin black wire on the antenne lead needs 12v+ for the antenne booster (should be connected to blue wire on blau, as with most all aftermarket radios)
the thick brown wire is your ground.
sounds like your constant 12v+ wire is either on the switched ignition wire or a fuse in the underhood fuse panel is blown, does everything else in the car work?
if you don't have good audio "definition" you may have speakers out of phase......does it sound hollow and tinny?
Brought to you by Carl's Jr.
Old 07-07-2003, 07:29 PM
