I`d for with little torch and grinder ,once you have the one side off use puncher and it will come off Ivan |
I just recently swapped out the hardware on my '84 exhaust. here what I used for anyone interested:
Went with M8-1.25 x 40 mm. Class 10.9 Zinc Yellow Hex Head Cap Screw bolts - Amazon ID (ASIN): B007IAEDIA M8 x 16mm Flat Washer High Strength HV200 DIN 125A Yellow Zinc Cr+6 washers: ASIN: B0CVD5HHQW Self Locking Copper Nut: https://www.pelicanparts.com/More_Info/0009903250.htm?pn=000-990-32-50-M36&bc=c&SVSVSI=0580 Could also use these: https://www.ipdusa.com/products/11455/Copper-Flanged-Lock-Nut-CRP-11621711954-Volvo-946036-948645?srsltid=AfmBOopg8gahyW8rR5wwMCJ17gsb_Cl9v1Q XSCVtZCn-0Cl1CNjvX1aq |
Thanks Matt for posting the hardware too. The links didn't work for me but I'll search for them on Amazon. I will definitely need a lot of those.
Yeah my exhaust manifold bolts are equally bad if not worse. I would have to drop the engine entirely to have enough room to work on all that. I'll try some heat, I have an air chisel where I may just have to try and slice through the nuts and drive them off. I got distracted trying to fix my door panel and waiting for the inductive heater to arrive from Amazon. I also appreciate the advice of not burning the house down, I'm definitely a fan of avoiding fire. I'll take some pictures as I go and probably come back to seek solace and deep breaths when I get frustrated ;) |
thanks for letting me know, replaced broken link with Amazon ID so can just search off that.
Just posting back--thanks to everyone for all the suggestions. Here's what ended up working for me in order of increasing desperation. I ended up using all the tools and learned a few new tricks using the air chisel.
One method I found helpful was to use a sharp chisel to cut a slot in the rusted nut, then shift to the angle to drive the nut counterclockwise. I didn't have to split the nuts, but the slot was enough to quickly get many of the nuts to rotate. This was much faster than trying to cut off nuts that wouldn't yield to the heat and nut extractors.
New exhaust is on and working great. I ended up filing out the rusty insides, grinding the mounting surfaces flat and smooth, and using stainless hardware and nickel anti-seize in the hopes that I will never get to experience this joy again. Here's a few photos. http://forums.pelicanparts.com/uploa...1754421954.JPG http://forums.pelicanparts.com/uploa...1754421954.JPG http://forums.pelicanparts.com/uploa...1754421954.JPG http://forums.pelicanparts.com/uploa...1754421954.JPG http://forums.pelicanparts.com/uploa...1754421954.JPG Again, thanks for the all the tips, it took some time but worked out well in the end. |
| All times are GMT -8. The time now is 07:12 AM. |
