-   -   BPR7ES okay to use in a 2.4T MFi? (http://forums.pelicanparts.com/porsche-911-technical-forum/1179443-bpr7es-okay-use-2-4t-mfi.html)
nigel911 06-26-2025 03:42 AM
Ordered BP7ES plugs and was sent BPR7ES's in error - understand the 'R' plug has a built in resistor - would they be okay to use in a stock 2.4T?
Just want to check before I install or send 'em back...
ed mayo 06-26-2025 04:41 AM
Yes, use them, non resistor no longer available
nigel911 06-26-2025 05:41 AM
Cheers Ed, much appreciated.
porschedude996 06-26-2025 05:57 AM
They will functionally work, but you may suffer possibly two things. Radio Frequency Interference (RFI), and a less stable spark. Also could effect you CD Ignition System. Even a cylinder misfire. I never experienced a misfire, but even NGK talks about it, see like below.
Years ago, in the days of the dinosaur, when we ran non-resistor plugs, you would hear it in your AM Radio. Sounded like an audio tachometer. I recall you could hear a car next to you at a stoplight that was running non-resistor plugs. The same for plug wires. A good example of this is the Chevy Corvette, with its Fiberglass Body, that didn’t shield the radio antenna. So the used a shielded Distributor. A metal box fitted around the distributor cap. Later Air-Cooled Porsche engine used shielded spark plug wires.
Link to NGK:
https://www.ngk.com/what-is-a-resistor-spark-plug
