123 Distributor 911SC
I am considering purchasing one of the 123 distributors from Partsklassic to install in my 79 911SC. Has anyone on here installed one of these and if so, any words of wisdom? Thanks
Old 04-23-2025, 06:08 AM
I bought one, actually rebranded for Pertronix with Pertronix CDI. It wasn’t cheap as you well know. The main reason i was moving on this digital/ programmable system was because the retard function of the advance pod was inoperative. After coming to a final configuration on my build, 3.0L, 964 cams, Euro 9.8 P&C’s, Acktung Kraft 1 into 1 out muffler, otherwise stock. I rethought 123 vs. the stock distributor. The stock distributor advance curve could be modified if need or desired. I could do that after my build. During one of my many, many, orders over 1-1/2 years, I found a new OEM Rebuilt unit with a new pod. It was 1/3rd of the Pertronix system. My final thought after running with the known good distributor, was why change. I’m probably not much over the stock HP and it really isn’t a “set you back in the set” kind of engine. Since then I installed a Digital CIS ECU from Andrew Cologne. This was primarily to… ahhh… assure the car would pass emissions tests in the future…??, That’s what I told my wife. I did improve the mileage, and the smoothness of the engine. Did I need it to pass emissions tests in the future? Probably not, it was running clean, so clean the emissions tech said “Wow, wow, I get newer cars in here that aren’t this clean.” Emission test is required before sale of car 4 years or older in Kalifornia and Santa Bumble County.
One has to ask (what am I building?). I think there is little HP to be found in just a 123 distributor.
Old 04-23-2025, 06:29 AM
PCA Member since 1988
Add to what porschedude said: Why do you want to change the dizzy? Is there something wrong with the old one? Have you modified the engine?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 04-23-2025, 10:20 AM
The distributor is need of an overhaul. Its a 6-7 week lead time to have it rebuilt or I can purchase a 123.
Old 04-23-2025, 12:51 PM
Who had 6-7 week lead time?
Old 04-23-2025, 01:36 PM
Get the 123 - and sell your stock dist to offset the cost.
Always learning.
www.aircooledporsches.com.au
See me bumble my way through my first EFI and TURBO conversion!
https://youtu.be/bpPWLH1hhgo?si=GufVhpk_80N4K4RP
Old 04-23-2025, 01:45 PM
I installed one in my 72 MFI and love it . . super easy to set up and I like the anti theft feature too. You might buy from 123Ignitionusa if you are in the states. I bought mine as my original dist was shot . . as someone mentioned, get the new 123 and sell your old one to offset the cost.
Old 04-23-2025, 02:03 PM
Correction, it is perma-tune, not pertronix.
I found replacement distributors (P/N 930 602 021 FX) on many sites for $950 and higher. Host has them for $1,273 with a core of $650 or so. If you choose one that has a core, make sure they have it in stock.
I didn’t like what perma-tune did to the 123 distributor the resell. They glass beaded the outside in a poor In a real amateur way.
I would doubt that the guy who performs my emissions tests would pass the visual on either the 123 or the glass beaded perma-tune.
Old 04-23-2025, 02:06 PM
Super easy swap, and it made a noticeable difference-starts smoother and runs a bit better overall. Just make sure to follow the instructions closely, especially for the wiring. Also, double check your timing after installation
Old 04-23-2025, 02:20 PM
If you are going to buy the 123 support Ed from 123ignitionusa. He works directly with the tech master ian (icarp) so it comes with built in support. Once ian is better of course.
83' Coupe - Ex-RaceCar
77' Targa Narrow Body - SC powered
Copper Brown Metallic
Old 04-23-2025, 02:27 PM
I am purchasing it from PartsKlassic, they also rebuild stock ones and they are quoting 6-7 weeks. I went ahead an purchased it along with their wiring harness.
Old 04-23-2025, 02:54 PM
PartsKlassic
Old 04-23-2025, 04:48 PM
I installed the 123 last year and don't regret it one bit - smoother at idle and overall, easier start-ups and +1 to Nditiz1 - buy the 123 to support Ed from 123ignitionusa, and Ian had been an immense wealth of knowledge and help in getting it running and tuned.
Old 04-23-2025, 05:49 PM
Installed and super happy with the results! I purchased the 123 from PartsKlassic along with their harness.
Old 04-28-2025, 03:35 AM
Why would you run a PartsKlassic CDI with a 123Dist, when the 123Dist with just a coil provides a better spark (longer dwell spark)?
Besides with a CDI, the ignition system has less reliability.
The CDI approach was only used because of the lack of high power switching semiconductors in the '60s & '70s.
Dave
Old 04-29-2025, 09:34 AM
dailydriven911's Avatar
I run both as well but was thinking of ditching the cdi in favor of this method. I've read arguments from both sides but I think I might just give it a try.
77’ 911S
Old 04-29-2025, 09:46 AM
So glad you commented on a post that had nothing to do with CDI. He mentioned buying the 123 from PartsKlassic not a CDI. Go back to your other CDI thread.
Old 04-29-2025, 01:56 PM
Glad you're learning about why CDIs are "history"!
Dave
Old 04-29-2025, 06:21 PM
I did not purchase a PartsKlassic CDI.
Old 04-30-2025, 04:38 AM
Lucky you!
Dave
Old 04-30-2025, 04:50 AM
