Are my spring plate bushings worn?
I replaced my rear shopcks tonight and I wanted to take a peak at the conditions of my spring plate bushings.
Here's what it looks like. Do they need replacing? I figure now is the time to do it since I'm going to need a rear end alignment and i don't want to get the car aligned to then have to replace the bushings and have the car realigned. Also, is an alignment required after reaplceing the rear shocks? Does it do anything to screw up the alignment?
They look pretty darn worn to me, I mean I have seen worse but you can see that its worn down the all of that top edge (where the lip now is in comparrison to the lower lip). I think thats right, its been a while for me. Anyway, I would go ahead and replace them if you can.
But, I could be wrong. *shrug*
Matthew “Sometimes the questions are complicated and the answers are simple.” |
Look worn to me as well.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Its time for new ones.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Southern Class & Sass
First, you do not need an alignment due to installing new rear shocks.
Second, what makes you think the rear bushings need replacing? Was the first pic taken with the suspension loaded? Is there some handling issue? Replacing parts before it's truly needed can get expensive.
Dixie Bradenton, FL 2013 Camaro ZL1 |
Czar of C.R.A.P.
It is however time.... Looks like a good 1/4" of bushing compression. Remember the list I gave you......
You are following that same path I did pretty closely.
66 912 Coupe 84 Carrera Cab Hardtop HC3.4 Hyper Carrera 2005 Dodge Magnum 5.7 HEMI Cabriolet Racing And Performance C.R.A.P. Gruppe #1 Put on some C.R.A.P. and drive.... |
In the first pic the suspension was not loaded. Car was jacked up tires off. I don't think I feel any signs of bushing wear, I'm not really sure what I need to look out for.
It's good to know that i don't need an alignment after replacing shocks. Now I have some time before I tackle the spring plate bushings. I'm doing my first AX in March so maybe I'll have them in by then. |
Hey Paul,
They are for sure worn, the cover plate should be perfectly centered around the Tbar end cap, yours is sagging. Still, it's not metal on metal YET. You show the passenger side, but I bet the driver's side is even worse right? As mentioned before, this is very much a DIY job, but will take the better part of a weekend if you work casually. I say you can easily get by for now though. Also, you can do this job and get your alignment pretty much back to how it is if you scribe the spring plate/trailing arm before starting ![]() -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
Thanks Chris. I'm going to tackle this one before the event at SF in March.
You won't believe how worn out my rear shocks were. I was able to compress them with almost no effort and they would spring back on the own. Geez!! I'm sure I'll notice a considerable difference now. |
Have fun. When you pull that spring plate and the torsion bar stays stuck in the plate end all your scribing will be for nought. The torsion bars never seem to stick in the torsion tube. I guess its Murphy's Law at work. Get an angle level and measure the angle of the sring plates before you start. Then if the torsion bars do come apart at the wrong end you can reindex to the same height knowing the angle. I got my level at Home Depot for less than 10 bucks. It has a magnet also which makes it perfect for reindexing the spring plates. Scale could be larger, though, for more exact angle reading. Good Luck.
69 911 2.3Ez 85 928S |
If you do tackle it yourself, here are some threads I made from my experience that I posted over on GruppeB.
http://gruppeb.org/forum/viewtopic.php?t=3047&highlight=spring+plate+bushings http://gruppeb.org/forum/viewtopic.php?t=2301&highlight=spring+plate+bushings Hope this helps!
Thanks for that thread, I'll follow that procedure.
You know they are real bad when they compresses by their own weight.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Oops. I meant they would not spring back on there own.
FWIW, here's a poor pic of the relationship between spring plates and cups on my car. This is with about 10 miles of wear.
Rob are you saying that yours is not centered? it sure looks like it to me......
If you are saying that it is not absolutely perfectly centered, then fine, the rubber must compress to some degree so I can agree with that. For reference here is mine after completion: Now, as to the worry about stuck torsion bars, what would that matter? Once scribed, the whole assembly comes apart anyway, so I am not following that. Please educate me ![]() -Chris
I notice two things regarding you photo. 1) Your suspension is unloaded. Mine is loaded. 2) You do not say what parts are installed. Urethane and brass compress way less than rubber. (Not to imply that either is a better solution than what Porsche derived.)
There's like 1/16" of rubber covering the torsion bar tubes on Paul’s 911. And I suspect there's another 1/16" of free space between the tub and the cup. That's 1/8" total of clearance. That clearance will most likely last a couple years minimum
Dixie Bradenton, FL 2013 Camaro ZL1 Last edited by Dixie; 01-31-2007 at 03:47 PM.. |
Agreed Rob.
OEM will compress a little. Paul's are very much useable as is for some time to come. If you figure it took 20ish years to get like this, there is plenty more time. They are worn though and new ones would most likely make a difference. They did on mine, but mine were kissing metal on metal. -Chris
by now, the rubber is likely rock hard -- the ride will improve when the work is done
it is not a huge job - I don't see the point in trying to eek out a few more years in a deficient condition.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Once a friend of Cliff
that hurts paul. you doubted my assessment? now i suppose you will be calling and have me over to watch you work on yer car some more? the two times ive watched you work on you car ive ended up with greasey hands too... let that be you jerks, his wife and kids were there.
call the raiderette of your choosin over that day and i will help with the bushings...... T$
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
