-   -   What material are non turbo 911 heads made from (http://forums.pelicanparts.com/porsche-911-technical-forum/1180240-what-material-non-turbo-911-heads-made.html)
Turbo_pro 07-14-2025 05:22 PM
We are looking at welding some 3.0 and 3.2 heads and my welder needs to know the aluminum compound the heads are made of.
I did a search and came up empty.
Thank you for your help.
dannobee 07-15-2025 01:02 AM
"Y" alloy Look on the corner of the combustion chamber side of the head and there will be a spot where those who cast them imprinted the alloy.
https://en.wikipedia.org/wiki/Y_alloy
4043 would probably be your best bet for filler rod.
Turbo_pro 07-15-2025 06:41 AM
Great, thank you.
Turbo_pro 07-15-2025 06:55 AM
How will 4043 react to heat treating? If the heads are exposed to intense heating during the welding process, heat treating might be required/desirable.
An option might be cryo treatment.
