Mixo Stritone Horn tear down?
Working on my horns noticed the low tone is blocked with mud dobbers nest. I have used warm soapy water to clean most of it and get it working. Still has a bit of rattle off tone sound.
https://www.pelicanparts.com/techarticles/pcar_com/964_horn_repair.htm?srsltid=AfmBOor4zEwlrEOCQtINye j_HKXofMfVqlYQ_-e-qD2Wy_TN61wYd7d-
This tech article regarding horns is missing the images
Does anyone have pictures of this horn taken to bits?
Old 07-18-2025, 09:34 AM
This is the assembly order trumpet. Note the orientation.
The flat bar has to make contact with the leads.
For what it’s worth, it’s dauber nest season so cover trumpets with screen and rubber band so they’ll nest up somewhere else. They tend to return whenever a nest is disturbed - like spiders. I use a puff of insecticidal dust to keep wasps away from cracks and crevices.
Old 07-18-2025, 12:28 PM
Yeah, I may use some RTV and layer of nylon stocking to bond on a "permanent" cover. RTV can be scraped off later if required.
Thanks for the images, it's nice knowing what's inside before letting the magic smoke out.
Old 07-18-2025, 01:21 PM
