3.2 Carrera Cruise Control not engaging
Good day!
I am having trouble diagnosing and finding a potential solution with my Cruise Control no longer engaging on my 1989 Carrera Cabriolet. I would appreciate any support and guidance from this forum. I am new and look forward to learning from this group.
Old 08-02-2025, 11:15 AM
I fixed my speed control by doing a search on eBay and found the little silver computer that is easily changed out way up front in frunk . I found a rebuilt unit. Under $100. I think the same unit was used on other European cars. Works perfect.
Old 08-02-2025, 11:38 AM
Fixed mine yesterday, the clutch switch has a little lever that comes out and it needs to be engaged when your foot is off the clutch. The lever is made from soft metal and I just had to bend it upwards for it to be in the correct position. To test, check for continuity between the cruise control fuse and pole number 85 on the relay. you should see a change when you press the clutch.
Old 08-02-2025, 12:29 PM
'87 Targa
Lammers post above is a great cheap first check. Otherwise:
Over the years, I've had 3 of the CC brain units fail (original and 2 used replacements). They either failed straight up, or would fail to hold speed then eventually fail completely. I understand some capacitors on the board, or poor solder joints, are common causes.
This time, I intend to use one of the CC rebuild services. I've come across this one: cruisecontrolrepair.com. There may be others ??
Old 08-02-2025, 12:30 PM
Originally Posted by KM 1989 Cab View Post
Good day!
The '88 and later 3.2 CC rarely fail!
Dave
Old 08-02-2025, 03:22 PM
Did you have to remove the switch completely to bend the soft metal upwards?
Old 08-02-2025, 07:36 PM
rokemester's Avatar
There are many good CC threads on this tech forum. I have an 87 Targa and I had my brain box rebuilt. Everything AOK after that.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 08-02-2025, 08:16 PM
The '87 and earlier are more likely to fail than the '88/'89 units.
Dave
Old 08-02-2025, 10:47 PM
Nope, I was able to reach in with my finger and bend it upwards, the metal is soft and it’s probably why it got bent out of position in the first place. I did remove the gas pedal and back plate.
Old 08-03-2025, 06:16 AM
Here’s a picture where you can see that the metal lever is bent downwards and not making contact with the clutch lever.
Old 08-03-2025, 06:20 AM
Thank you so much for the clear direction and follow up. Just completed and now buttoning up the driver footwell to road test. I do have another question for you based upon other posts and testing the #85 pin on the D or #4 relay. Do you have a pic referencing the #85 pin to electrically test the clutch switch with a voltage meter?
Old 08-03-2025, 09:22 AM
If you’re looking for a specific reading, I don’t have a pic. It would be dependent on whether I measure before or after the fuse anyway . I just looked for a fluctuating when I pressed the clutch, I achieved some and that was enough.
Old 08-03-2025, 12:55 PM
It's a simple test just using the ohms function of the VOM!
Dave
Old 08-03-2025, 01:56 PM
