And off she goes! Media blasting the shell before epoxy primer. I ended up stripped every nut, bolt, support, etc. Fenders will come off before the blasting.
1971 911T (Tangerine) 1973 911T (Light Yellow) 1978 911SC -- "Northy" 3.2 twin plug 1990 911 Carrera 2 |
For a color change on a car you intend to keep, I think you are doing it correctly. Media blasting removes all the original color. I color changed my car and we did the same thing. Today, about 6 years after the repaint, with about 16K miles on her, it still looks perfect. We used a single-stage paint and had PPF applied to the front end, A-pillars, wheel well lips and door cups. Good luck and have fun. Michael
'71 914-6 #0372 '17 Macan GTS |
Smaller parts are painted black now. Thanks for tips on this one guys.
What condition is your Glass Rubber?
My cars rubber fit perfect before replacement. I massaged the old rubber and reused it. Turned out as good as before. The new Uro seals I hear have fit issues
1980 911 - Metzger 3.6L 2016 Cayman S |
Nice!
Tru6 Restoration & Design |
I was able to save the rear quarters and front door rubber (quarter? not sure what you call that one). The rest I need to replace and I have OEM in my workshop now.
Is the same black we used for the trim/accessories suitable for the black accents on the rockers and rear bumper? Or do we use something else for those details?
All disassembled and ready for blasting. Will start a new thread for my re-assembling process.
Making good progress on paint and assembly. Doing some minor RS and ROW modifications while in shell format.
- RoW side markers - Removed some unnecessary brackets - RoW glovebox I was going to do some of the seam welding, but the car was already in epoxy, so I skipped that. I will add some swaybar reinforcements later. ![]() ![]() ![]()
Cool project.
Dave Project: 1985 Porsche 911 Carrera Coupe 3.2 to 3.4L "Carina" PCA Member- Sacramento Valley region |
What is the general rule how/where the factory painted the ineriors areas black? As well as the door panels. I took some photos while I was ripping the car apart. Did they use a brush?
Doors too.
I have a vague memory that they stopped painting the edges of the doors black in the 91 updates but I could be wrong.
Congrats on the progress. The car needed so much a color change was the right choice. Did you have much rust under the front fenders? Good that it was a Ca car. |
Intersing, mines a 1990, but I'd be curious to see some 1992 models, I'll look around.
It's a WA car for the first 30 years of it's life. The only rust we found was in the cowl area, but we fixed that up!
I have a 91 less than 20K original miles that was Washington based most of its life and there is not a hint of corrosion anywhere. May as well be a new car.
I have a 90 also with less than 20K original miles that was Cali based all its life but still in proximity to the ocean and while it’s a rust free car there is some chalkiness on items like door hinge pins or other plated items. Nuts and bolts on the Ca car are usually a little tougher to break free. Last edited by Balisong; 10-20-2025 at 10:57 PM.. |
Car is painted! Now to add some black accents on interior etc., polish and start to re-assemble.
Nothing like a chassis in fresh paint.
Hopefully you can share the approximate $$$ of the repaint. Looks like you did a lot of the prep - delivering the car shell.
What was used for blasting? Any trouble getting epoxy up under the dash and such? |
What did you end up doing on the underside of the chassis ?
For the underside, I followed the factory patterns (from what I can gather) of body color wheel wells, rockers, and overspray in the other areas of the pan, etc. We Epoxy primed the whole shell, seam sealed, and masked up everything.
1971 911T (Tangerine) 1973 911T (Light Yellow) 1978 911SC -- "Northy" 3.2 twin plug 1990 911 Carrera 2 Last edited by wprater; 11-15-2025 at 03:58 PM.. |
