1971 911T Parcel Shelf Replacement
Good afternoon Pelicans,
Can someone please post some pictures of what an original parcel shelf should look like on a 71 911? Mine has been replaced and we are currently going back in to remove it and my body guy would like some detailed pictures of what an unmolested, factory Porsche parcel shelf looks like installed. Thanks for the help! Kind regards, Sebastian
1971 911T Irish Green Coupe |
PCA Member since 1988
Are you talking about the metal shelf underneath the visible covering, or the covering?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
Looking to replace the metal underneath. Thanks.
Been here a while
this might help
looking for 1972 911t motor XR584, S/N 6121622 |
If we are talking about the metal, a tidbit of information. The only difference I have seen between the early and late models is the early has a bracket to install a loop to connect a luggage hold-down strap. In straining my memory, the other end for a luggage strap is on the vertical panel behind the heels of a potential rear seat passenger, some 4-5 inches above the floor. Upper bracket shown in Blucille’s above images.
Ayo Irpin, Ukraine!
Blue’s pics look like ‘72/73 which I believe is different from the earlier cars for sure, my ‘70 has different stamping and I believe ‘71 should be the same as ‘70. It’s more than just the luggage strap brackets.
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
Been here a while
Blucille is a very early 72. 11/71 production
Do you have any pics you could share?
![]() ![]() Finished rear crossbar area, about to move into the parcel shelf soon.
Ayo Irpin, Ukraine!
Sure, here’s my ‘70. 12/69 build.
Ayo Irpin, Ukraine!
The two holes in the firewall just above the rear seat pad were from the PO. He mounted harnesses using fender washers.
I retract my statement. I see it is different, but isn’t it functional the same?
Seb my guy has a 69 on a rotisserie right now, parcel shelf is in perfect shape. In fact that tub is just about the cleanest, most rust free, and straightest we have ever seen. I can see if I can take some pics tomorrow, if I remember. Also, you might go take a look.
I’m picking up my POS in the morning tomorrow, as long as there is no rain.
Chris - Insta @chrisjbolton 1975 911s Insta: @911ratrod steel wide body, 3.6 conversion 1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line) 2001 996 Turbo - ~54k miles |
Ayo Irpin, Ukraine!
The '72-'73 different. Also, if I'm not mistaken the pop out window interior trim pieces are shaped a bit differently, different lengths where they fit up to the parcel shelf panel as well.
Thanks for the pics guys. Keep 'em coming if you can. Specifically looking for detailed pics of the brackets that hold the hinges for the decklid. Thanks!
Ayo Irpin, Ukraine!
PM sent.
I have a stripped '69 in the garage. If you need any specific pics drop me a DM with your # and I'll send whatever you need tomorrow via text.
Your inbox is full.
