speedo gear needed for a kph to mph retrofit
I have a 1980 sc originally a Belgium car imported to the usa. it now has a mpg speedo. The back of the mph face plate says 2-28-85 w3301 mph the rest of the Speedo is dated 6-79 I'm assuming it's the original kph Speedo retrofitted to mph when the car was imported back in 85.
i originally bought the standard mph usa 20x30 replacement gear it didn't fit. Then i i was told i need the 20x30 row gear so i ordered that, it also didn't fit. ( the orange gear is the gear in question) The large tooth on the orange gear fits the odometer motor but the little gear part of the orange gear is to large to mesh with the original gear in the speedo. The original gear was totally disintegrated so I have nothing to reference . .. does any one know what gear ratio i should use to fix a kpm speedo that was retrofitted to mph when the car was imported to the usa? from what i can see there are 5 more gears that were used 20x20 20x21 20x22 20x23 20x29 im sure one size should be specific for a kph to mph conversion the vendor i spoke with didn't have the answer. thanks for your help Regards Ned ![]()
Ned G. 1976 row turbo i/c k27raptor turbo sc cams in a 80sc wide body Last edited by gorskined; 07-18-2025 at 05:35 AM.. |
trying to load a better picture
Ned G. 1976 row turbo i/c k27raptor turbo sc cams in a 80sc wide body Last edited by gorskined; 07-18-2025 at 04:56 AM.. |
![]() im assuming the correct gear should be a 20x20 20x21 20x22 0r a 20x23
Ned G. 1976 row turbo i/c k27raptor turbo sc cams in a 80sc wide body |
How many teeth are on the large side of your black gear?
Sent from my SM-S931U using Tapatalk
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
i count 49
Just to confirm 20x21 gear its a perfect fit. The odometer and speedo works great thanks
Have you still got the km/h face?
