915 Transmission year/type investigation
I'm hoping someone out there in Pelican world can help me identify which transmission I have. It is a magnesium case.
The keel has been completely ground off so there is no transmission type or serial numbers available.
The bell housing has a casting number of 915 301 101 1R
The other casting number is 915 301 102 0R
I have uploaded some pictures to help.
Can anyone tell me around what year this transmission is from and the support for your answer???
Old 08-19-2025, 05:43 PM
Electric speedo, 76/77.
206 637 4071
Old 08-19-2025, 06:41 PM
What John says. 100mm drive flanges. Nyloc nuts tell us it’s been apart, I wonder if a LSD is installed as ALU tag would indicate.
Old 08-19-2025, 07:15 PM
I very much appreciate this. Please understand I am not a mechanic. This car came with LSD according to the build sheet. It is indeed a 1976 model. I was not aware that the aluminum tag indicated a limited slip.... I turn the drive flanges and the opposing side turns in the opposite direction... doesn't this mean that the LSD is not installed?
Old 08-19-2025, 07:41 PM
Yup, in neutral, with LSD, drive flanges would rotate in the same direction.
Old 08-19-2025, 07:48 PM
gearhead
It’s really easy to pull the side cover and find out. A wornout factory lsd with no preload will sometimes behave like it’s open.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 08-20-2025, 06:14 AM
