-   -   Trying to remove bilstein cartridge from 88 (http://forums.pelicanparts.com/porsche-911-technical-forum/1181028-trying-remove-bilstein-cartridge-88-a.html)
joe88911 08-02-2025 01:17 PM
I’m trying to remove a Bilstein cartridge from a Boge strut on my new to me 88.
The green outer sleeve slid out. But the inside part won’t budge. I’ve gently tried to tap on the reinstalled top washer/nut and smacked around in the strut with a dead blow. She seems really stuck. I’m afraid to get medieval on it and damage it.
I’m trying to get it apart because I suspect the cartridge is incorrect to the strut. There is side to side play in the strut/cartridge when the gland nut is tight.
Cartridge F4-P36-0114-HO
Boge 911 341 041 02
Any advice?http://forums.pelicanparts.com/uploa...1754165988.jpg
Dpmulvan 08-03-2025 05:39 AM
http://forums.pelicanparts.com/uploa...1754224766.jpg
joe88911 08-03-2025 03:17 PM
These things are supposed to just fall out, right? Not retaining pins or anything?
Joe
digdug 08-06-2025 07:43 PM
The gland nut is the only thing holding it in. On mine I had the spindle off and for the side that was leaking I had to hit the spindle with a large mallet really hard while holding the strut. Eventually it released. However if the strut housing is bent or dented it’s nearly impossible to get it to release.
Queefchief 08-08-2025 04:49 AM
You need to remove the bolt that goes through the bottom of the strut as pictured to remove. This separates the insert from the housing/ball joint.
GH85Carrera 08-08-2025 06:43 AM
On my 85, I just removed the large "nut" that is a pain to remove on the top of the cartridge. Your photo shows it as removed. On my 85, the insert just pulled out with a lot of oil dripping off. I had to swab out the oil with paper towels.
Maybe the 85 does it different. I did NOT want to remove my strut, just the insert.
http://forums.pelicanparts.com/uploa...1754660483.jpg
Many people just use a large pair of channel lock pliers.
I can't image what is holding your insert in place.
Dpmulvan 08-08-2025 06:51 AM
Joe
Correct, might be easier to remove it from car and put in a vice.
Dpmulvan 08-08-2025 07:04 AM
It’s a boge strut there is no bolt holding the insert.
jaxxon99 08-08-2025 07:33 AM
I had the same issue, it was basically stuck in there due to suction and I could not remove it. Tried a method I found on the pelican board using a piece of PVC pipe that is the right diameter on the top part, put the bolt and top cap on and used an impact wrench and it pulled it right out.
nickelplated5s 08-08-2025 07:53 AM
GH85 - Some people use light weight oil to help with heat transfer from the shock itself. If yours wasn't leaking that's why it was there.
GH85Carrera 08-08-2025 11:28 AM
Actually, it was from the old leaking Bilstien insert. I installed it many years ago when I did a full suspension upgrade. Both front shocks were leaking. I saw oil on the struts and knew something was not right.
I just replaced the inserts with new Bilstiens.
I have owned my 911 for 30 years. I have a really hard time finding anything I can blame on the previous owner anymore.
PeteKz 08-08-2025 10:55 PM
Yeah, I hate that guy too. After 33 years, there isn't a part on my car that my hands haven't touched. I have to look in the mirror frequently.
GH85Carrera 08-09-2025 06:23 AM
Yep, and on occasion say what the heck were you thinking ya dummy.
nickelplated5s 08-09-2025 02:43 PM
OK, I like Jaxx's idea but I had to think about it. A PVC cap with a hole in and washers might work but might split. I'd suggest a cast cap instead. If you go that route get one big enough you can use the gland nut to protect the threads.
