Brake lights and sunroof stopped working after replacing turn signal switch 76 911
A few days ago I replaced the turn signal switch on my 76 911S.
After the replacement, the low beam, high beam, and all functions related to the switch worked fine. However, I noticed that both the brake lights and the sunroof stopped working right after I installed the new switch. :eek: Could these issues be related to the turn signal switch replacement, and if so, what should I check first? Thanks in advance for any suggestions! |
Check fuses first. Otherwise, it's likely that you pulled or bumped something that loosened the connections to those circuits.
