-   -   964/993 distributor rebuild issue (http://forums.pelicanparts.com/porsche-911-technical-forum/1181352-964-993-distributor-rebuild-issue.html)
jimtweet 08-09-2025 08:46 AM
So I’ve done a handful of these in the past and this is the first time I’m running into this issue.
I just had two distributors apart to replace belts. Got everything assembled and ready to put the gear on bottom and pin…
When they came apart there was two shims and a washer before the gear on both…
After new belt and assembly I can not get the gear/shaft hole to line up unless I remove both the shims.
I have taken these both apart now two times and verified everything inside is correct what would have changed that this no longer lines up
