Winter is on the way, SC Oil Question
The cold weather is coming up, what is the best oil to use in the winter time? I am planning on changing the oil this weeked when I replace the front wheel bearings,brake pads, and rotors. It looks like I am going to go with 20W50, is this a good choice? Has anyone ever had any troubles running 20W50 for a 911SC in the winter? I've heard to stay away from synthetics, Are any brands preferred over others for a SC, Mobil One Vs. Pennzoil VS. Castrol? I appreciate the feedback
It'll be legen-waitforit
You are running you're car in the winter?
![]() It depends on the winter, but 2050 is too thick depending on the temps. 10W30 should be fine, but again it depends on what you consider winter.
Bob James 06 Cayman S - Money Penny 18 Macan GTS Gone: 79 911SC, 83 944, 05 Cayenne Turbo, 10 Panamera Turbo |
Our winter temps can get down to freezing, usually it is pretty cold (avg. temp 20's- 30's) after November. A friend of mine recommends using 10W30 as well, others I know who own SC's advise me to use 20W50.
According to the owners manual for my '78, for year round use:
"... use multi-grade oils SAE 10 W-50, 15 W-50 or 20 W-50. The 20 W-50 oil should not be used at constant temperatures below +5 degrees F/-15 degrees C." From this it would appear 20W50 would be fine for winter (in your area), you might look at using a 10W40 or 15W40 however, both should be readily available in any name brand (BTW, I won't use Pennzoil even in my lawnmower). It would also appear that 10W30 is much too thin (except, perhaps, in the most extreme cold, e.g. consistantly below zero F.). Jerry M '78 SC |
I like the Mobil 1 0W-40. It's great for cold starts.
Thanks Everyone, I changed my oil today with castrol 20W50 today. The SC runs much smoother than before.
