-   -   Help Request: '78SC Smoke out intake, Quit running. It's not the CDI! (http://forums.pelicanparts.com/porsche-911-technical-forum/1182662-help-request-78sc-smoke-out-intake-quit-running-its-not-cdi.html)
b. hilliard 08-21-2025 06:24 AM
Hi all-
I'd loves some help diagnosing. Apologies for the novel, but unfortunately the car broke down on a road trip and is currently 200 miles away, so repair work attempts have been intermittent. I'm trying to get it running again for the trip to Watkins Glen Historic weekend soon!
Here's the details:
1978 911SC, 170k miles, owned it for 24 years. Lots of seat time.
Prior to road trip:
-New Beru cap and rotor. Basic maintenance always up to date. Historically has been rock solid and reliable for long and short trips. Within last few driving seasons preventative fuel pump, filter, accumulator, injector seals, cleaning all WUR connections, a few things I'm forgetting, etc. Pop-off valve installed. Older battery but always good and strong.
During Road Trip:
-Warm day, approx. 175 miles into trip. Tach needle bouncing some but has been for at least this driving season maybe longer. Oil temps a few degrees above what is normally 9 o'clock on the gauge (assumed hot/ humid responsible but hindsight maybe not), steady 75 mph. Felt a hesitation/ cutout that I've never felt, seemed to catch and continue. Then a colossal backfire out the exhaust (SSI's, Bursch muffler) that was like a shotgun. More hesitation. Pulled off highway, found nothing, cooled off, started again and continued. 10 miles later, more hesitation at cruising speed, backfire, pulled off and let cool. Continued on secondary roads, temperature slowly rising a bit above 9 o'clock, started to climb a hill in 2nd gear, hesitation then a colossal explosion of white smoke out the intake, engine audibly dieseled for split second and quit. Properly scared at this point I towed it to a safe storage location and left it there.
Return and Repair/ Diagnosis
-Pulled all plugs, turned engine by hand, all felt fine. Installed new plugs
-Pulled distributor and replaced green wire. Distributor pickup coil Ohms out within spec
-Procured known good CDI, installed and got a fat spark while cranking over.
-Pop off valve and airbox seem intact and healthy
-Brought an old school oscilloscope and probed pickup coil while cranking. Showed approx 5 volts peak to peak.
-Coil resistance also within spec. Old school black Bosch coil.
-Older shielded/ grounded Beru plug wires, Ohm'd out fine.
Started Car:
-Idled a bit rough and seemed out of sorts compared to normal but thought perhaps it was cleaning out old fuel from original failure.
-Tach needle bouncing like crazy.
-Drove in first/ second gear, never above 2200 rpm for about 1/2 mile uphill and could tell it wasn't quite right, turned around and it hesitated/ lost power while coasting, more white smoke out intake, dieseled for a split second and quit. Properly scared again, it's back in storage.
So, I am returning this weekend for round 2. Can the experts chime in on what I should do next? Thank you in advance!!
kmcteer 08-21-2025 11:32 AM
Hmm, my first thought was your timing shifted. I assume you set it when you RRd the distributor? Is your distributor mechanical and vacuum advance acting right? Definitely take a close look at the Green Wire (routing, pins in connections)
Maybe do a sanity check on your CIS system. Is your fuel distributor Needle dropping after you lift and drop the air flap? Pull the injectors and do a fuel flow check at various flap levels. I personally wouldn't check absolute volumes, just that it is acting right.
Other idea, engine/transmission grounds?
kmcteer 08-21-2025 11:34 AM
duplicate
trials935 08-21-2025 01:16 PM
Look carefully at the new distributor cap orientation and locating tab, my customer was sold a cap that when installed properly was clocked wrong. Also rotor button was bubbled on top of the epoxy fill between the center and end brass piece, the internal resistor had overheated
b. hilliard 08-21-2025 02:00 PM
Thank you @kmcteer, in my rush I did not check the timing after reinstalling the distributor. I did mark everything and put it back as such, but it doesn't mean it's quite right. I can check the advance, but I believe it's also working correctly. I feel like even if the timing/ advance was off slightly, it may not run perfectly but likely wouldn't just poop it's pants after 20 mins of running?
The new Green wire checked out from distributor to the first connection (old one not great, male connection had deteriorated) but will have to double check from that connection back to the CDI.
I'll look back into the CIS as you suggest as well.
I didn't look at the eng/ trans ground but will. I know there's one by the transmission, any other major ones that might cause issues with running?
@trials935 great point. I'll look, and unfortunately I think I threw my old one away! I had done a few hours of driving on the new cap/ rotor before the road trip, so it was working for a while....
nickelplated5s 08-21-2025 02:47 PM
Oil leak into the intake.
b. hilliard 08-21-2025 03:04 PM
Hi nickelplated5s, interesting thought. Where would I look for that to see if it's a problem? Could that cause it to shut down/ backfire/ etc?
nickelplated5s 08-21-2025 03:25 PM
Tow it home and try a compression/leak down test. You stated plugs are cleanish so my guess is rings, valve stems or seats i.e. something internal. Not going to be fun.
Bobboloo 08-21-2025 03:30 PM
Appears to be an electrical problem. Losing power and then getting it back followed by a backfire in the muffler is a tale tale sign. Un-burned fuel got ignited after the fact in the exhaust = boom.
The Beru wires you have are notorious. Find a replacement set you can temporarily use to replace them for troubleshooting. Also, there is a good possibility your timing is off so check the timing with a timing light.
rwest 08-21-2025 04:52 PM
A bouncing tach is not okay. I think if you figure out why it is bouncing, you will solve your problem.
Maybe do a search and see if you can find another person who had a bouncing tach and how they solved it.
b. hilliard 08-21-2025 05:33 PM
Thanks @Bobboloo, I'm leaning towards electrical issue as well. It seems like an ignition/ spark cutting out (I'm assuming unburnt fuel is continually dumping and accumulating either in the hot exhaust = backfire, or in the intake = pop off valve venting ignited fuel and lots of white smoke out the intake) is what is happening.
Can you expand on the Beru wires being notorious? I've always assumed they were a good product, although they have been in for probably 40-50k miles.... but I'd need to check my log book which is with the car. I don't have access to another set to swap in, perhaps I should buy new ones to eliminate the issue? I see the prices have gone, well, UP! Is there a manufacturer that's trustworthy, but less than the $850 Porsche is charging for their OE?
Will reset the timing with my light this weekend too.
b. hilliard 08-21-2025 05:40 PM
Thanks rwest, I feel like I've heard that too regarding the bouncing tach but cannot figure out what the various symptoms/ solutions are. Even with the known good CDI that I bought and swapped in the tach bounced, although it produced a nice spark where the the original CDI did not. So the car ran, but not for long!!
rwest 08-21-2025 05:48 PM
Have you tested your voltages at the battery at rest and when the engine is running? Also check what the voltage is going to the CDI.
b. hilliard 08-21-2025 08:50 PM
rwest I have not done that since this issue reared it's head, so I will add that to the list. Thank you!
Can a malfunctioning alternator or weak battery cause major issues similar to what is happening?
Bobboloo 08-21-2025 10:02 PM
The last thing you did before this problem was change the cap and rotor. That's the first place to look. Make sure your plug wires are securely connected.
You should also inspect the ends of the sparkplug wires where they connect to the sparkplug for any that have discoloration and corrosion to pinpoint a problem wire.
If you need new wires, Clewitt Engineering sold by Pelican are a great choice.
b. hilliard 08-22-2025 07:43 AM
Excellent, thank you Bobboloo. All great thoughts. I'm really starting to think the cap/ rotor could be an issue as it is responsible for firing ALL the cylinders which seem to cut out at once. It's not an intermittent misfire, it's a full shut down and then igniting all the unburnt fuel in the wrong place.
Bobboloo 08-22-2025 07:57 AM
Good datapoint on all cylinders cutting out.
Check the wiring from CDI all the way to the distributor to make sure everything is seated properly.
6-pin connector
Green trigger wire
Coil to distributor
12 volts and ground wires on coil
12-volts to CDI
Ground to CDI
(You can turn ignition to run position and listen to hear if the high pitched CDI whine cuts in and out as you giggle wires if that helps you to troubleshoot)
Bobboloo 08-22-2025 07:59 AM
Maybe switch back to original cap and rotor if nothing catches your attention.
b. hilliard 08-22-2025 08:11 AM
Unfortunately I chucked the Bosch cap/ rotor that was in there previously, which is rare for me. Typically I keep functioning old parts around!
rwest 08-22-2025 09:09 AM
Look at this current thread- seems like one poster had bouncing tach from a bad voltage regulator.
http://forums.pelicanparts.com/porsche-911-technical-forum/1182699-voltage-regulator-alternator.html
b. hilliard 08-22-2025 12:30 PM
Thank you rwest, good intel on the alternator.
This begs the question; can starting/ running the car (even just to test the alternator and voltage regulator, etc) give the potential of spiking power and actually taking out my new CDI? The last thing I need is to ruin the new one which leaves me unable to diagnose! It seems to me it would be a poor design if a voltage spike from a failing regulator could take out the "brains" of the injection system too!!
I will be able to do some tests tomorrow, so I'm getting a pretty good list of potential issues.
mysocal911 08-22-2025 05:04 PM
What does this mean, e.g. you saw the CDI run perfectly on another car?
b. hilliard 08-22-2025 06:50 PM
Hi mysocal911, I bought a second CDI as a “known good CDI” brought it with me when troubleshooting the issue (the car is 200 miles away from me) The new CDI produced a nice spark. Knowing that that was good, I left it installed while trying to find the other issue that still plagues it, causing the car to die out.
Demetri 08-23-2025 09:45 AM
My bouncing tach issue was caused by my old battery.
b. hilliard 08-25-2025 04:32 PM
Hi all-
A partial update for those interested; I made a list of everything people have mentioned and dug into the car this weekend. It was slow going without many of my tools and no lift, but essentially was able to cross everything off the list except one, I ran out of time to try starting and driving it again!
Every relevant wire, coil/ pickup, ground and fuse block was tested for resistance/ continuity, cleaned and reassembled. The final thing that got my attention however, may prove to be the most crucial. The huge Interstate battery that's been in there for a while and always sounded healthy and performed as expected, was on my trickle charger all last week. I disconnected before doing the 2 days of work and the last thing I did was hook up my multi meter so I could watch it during load, idle and then test driving. Initial reading? 12.1V. Crap, this could be a smoking gun....
I'll buy a new battery this week and head back to VT in a few days to put all the pieces of the puzzle together. Hopefully it runs as it should with all this new work and a fresh battery, the Hilliard Vintage Grand Prix weekend at Watkins Glen is coming fast!
Ian Comerford 08-25-2025 11:26 PM
As above I would solve the bouncing tach first and look at either a failing voltage regulator or alternator as the most common causes
Tom_in_NH 08-26-2025 09:59 AM
Bouncing tach is often an indication of a bad voltage regualtor.
zuch 08-26-2025 10:26 AM
I'm in Williston Vermont. Yell if your car is close and you need a hand. I have a lift, oscilliscope, tools, etc.
b. hilliard 08-26-2025 03:15 PM
Hi Zuch, an amazing offer but I'm up in the Northeast corner so a good distance away. Thank you so much though!!
b. hilliard 08-29-2025 03:36 PM
Another update as I was able to spend some time with the car today. Installed a fresh battery and started the car. Once warm, I re-timed it at idle and kept hearing an odd noise that seemed to be coming from the distributor. Also odd to me was that the timing mark seemed to jump around a lot and occasionally the timing light failed to flash consistently. Was it misfiring, perhaps?
I installed a fresh Bosch cap and rotor (the old Beru one I removed has only 3-400 miles) and it sounded better but still made some low-volume metallic honking sound as the distributor spun around. Started the car again, warmed it a bit and tried some 1st gear driving.
Tachometer still bouncing. Engine seemed to run OK, not great. A bit rough still, especially at idle/ low RPMs.
Made it a 1/4 mile up the road, turned around and it promptly died coming back down the hill.
It seemed like it just lost all spark again, once it started warming up.
I pulled the distributor to check the resistance and continuity at all 6 points as we spun it around by hand. That's when I discovered the same metallic honking "noise" as I spun the distributor...it sounded like metal binding up, and could feel the vibration, like a dry bearing. My understanding is that there is only bushings inside (no bearings), so how are these lubricated? Do they run dry? Vertical and axial play seem very minimal, but the sound is horrible when I spin by hand and give it some vertical pressure. Please see attached video for the sound!
https://cdn.mileshilliard.com/porsche.mp4
rwest 08-29-2025 04:28 PM
There is a felt pad down the shaft under the rotor that gets a few drop of oil occasionally.
Have you checked voltage at battery when at rest and when charging yet? That should tell you if your alternator is acting up.
b. hilliard 08-29-2025 07:16 PM
Hi rwest, yes the alternator/ battery / system is spot on and looks to be cleared in all situations.
The felt has been oiled a few times over the years, particularly recently but maybe it’s not been enough? Is that the only way the brass bushings are lubricated?
A930Rocket 08-29-2025 07:48 PM
I’m not sure of the names, but is it possible one or more of the 6 point star is rubbing on the brown circle within somewhere?
Disassemble it, and spin as you take parts off to determine where the noise is.
http://forums.pelicanparts.com/uploa...1756522050.jpg
b. hilliard 08-30-2025 07:34 AM
Yes, something seems amiss inside. Sadly I don't have all my tools with me so I'll have to bring it home and tear into it I think. Am hoping someone familiar with these distributors can tell me that either it sounds normal and just needs cleaning/ re-oiling, or I should get a whole rebuild kit and deal with it later. Getting it running in time for Watkins Glen Vintage races is fading fast!
b. hilliard 10-27-2025 07:58 AM
Hi all, update time in case anyone is interested.
I decided the odd noises heard by rotating the distributor (shown above) were decidedly NOT normal despite never having torn one down. I ordered a full rebuild kit from PartsKlassic and dove in. What I found was a distributor whose advance mechanism (both mechanical and vacuum) had frozen from corrosion/ lack of lubrication, and shims/ spacers that had long departed allowing axial play. Long story short, with a few head scratchers along the way but plenty of patience, it was rebuilt and feeling proper. I traveled to where the car was being stored, installed it and set the timing. Instantly I knew it was better as the timing no longer jumped around/ skipped and was easy to dial in. Also, my tach needle STOPPED BOUNCING! I crossed my fingers and drove the 200 miles home with no backup plan other than a Hagerty Insurance roadside coverage. The car ran great, really great, likely better than it has in LONG time and I've owned it 24 years.
Cheers!
