kwikt 911's Avatar
Which alternator for 1972T
I'm planning on replacing my original marchel alternator on my 72 911. Which one is direct replacement using original external regulator and direct wiring plug and play.
Old 09-02-2025, 06:18 AM
HarryD's Avatar
If you are interested, I have an internally regulated alternator from my 1973 which should work for you.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 09-02-2025, 07:49 AM
tobluforu's Avatar
Why, is your old one kapoot? If it's on its last leg, check around your area as there might be a shop nearby that will rebuild it. Or Harry will hook you up.
Old 09-02-2025, 08:11 AM
Rosco_NZ
Send a message via Skype™ to Rosco_NZ
Some are of the opinion the early system with the seperate voltage regulator is better, as it’s not exposed to heat and breakdown. I rebuilt mine (bearings and new carbon bushes) and had the regulator tuned (they drift up & could boil your battery). I’d suggest keeping original if possible.
Old 09-03-2025, 02:28 AM
kwikt 911's Avatar
Yes that's my intention to keep it OE since it lasted this long. I owned this car since 1985!
Old 09-03-2025, 06:03 AM
I have always had great success with a local auto electric shop. Usually Bearings, brushes, and diodes, all cheap, and you are ready for an other 50 years. Take your VR with you a they can often check it out. Rob
Old 09-03-2025, 01:15 PM
