clutch pedal Play
This is my 86 911 3.2 with a 915. Having some shifting issues,
https://youtube.com/shorts/mj2DVqeNiaY Not sure if I can embed this link. Should my Clutch pedal have this much play? this doesn't seem correct. Thanks The omega spring seems loose also. https://youtube.com/shorts/WBsw79xfPqs Last edited by Brickwhite; 08-28-2025 at 08:54 PM.. |
you should try to look up how to adjust your clutch cable..that could be your only problem....since there is no other info about your 911
ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Still here
What doesn't seem correct ?
