I bought the coupling and carriage bolt, but after looking at the pictures online, the square part of my carriage bolt is too thick. I need to find one that matches the bolt online so it doesn’t bottom out. Also, I will need to cut the coupling down.
Back to Lowe’s… http://forums.pelicanparts.com/uploa...1756993855.jpg |
Interesting how thick that square carriage retainer area is.
Another option is to add a washer. There is enough room between the spring and regulator. Might have to file the corners down where it protrudes too tall. I thought about a washer just to increase the contact area at that point. When I cut and shortened my coupler (barrel nut), I installed it so the flat cut-off side was toward the regulator, for that reason. (The coupler itself is rounded a bit.) |
I filed a carriage bolt down so it would fit in the slot on the regulator. Started to file the square part down, then realized a regular screw would work. Here's what I ended up using:
http://forums.pelicanparts.com/uploa...1757009920.jpg http://forums.pelicanparts.com/uploa...1757009931.jpg I still had to file some off the head (flattened it out a bit) to provide clearance between the pieces. I applied some red Loctite before assembling. |
| All times are GMT -8. The time now is 04:11 PM. |
