Fuel pump no power
Hello, I have a 73 E , the engine turns but the fuel pump is not getting power. I have replaced the relay. I just left the ignition on to where the fuel pump light should come on
And after 30 seconds or so the light and pump were powered then nothing.
Has anyone had similar issues?
1987 carrera coupe 47k
1974 carrera targa #12 lime green all original
1982 911 sc targa 68k miles
Old 01-28-2024, 09:00 AM
PCA Member since 1988
The 1973 wiring diagram shows no relay or fuse. The power goes from the ignition switch directly to the pump. If the pump worked intermittently, you could have a pump going bad. When was the last time it ran, and what have you done since?
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners.
Cars are for driving. If you want art, get something you can hang on the wall!
Old 01-29-2024, 01:21 AM
Thanks for the reply, I did find the problem
Bad wire connections at the fuse panel , fixed for now
But will eventually need some new wireing.
Cheers
Old 01-29-2024, 02:13 PM
HKZ Bob's Avatar
I have the same issue, can you please post a picture of the defective connection?
Greetings Robert
Gesendet von meinem 2311DRK48G mit Tapatalk
Old 07-06-2025, 01:00 AM
Kroon Wire Harnesses
The fuel pump wire is in the tunnel harness, its a 2,5mm2 red-green one and connected to the 7th fuse of the 10 pole fusebox. From the pump there's a small fuelpump harness connected to a 2 pole"T" shaped connector in the engine bay.
Specialized in Classic Porsche electrics
www.kroonwireharnesses.com
Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses
Old 07-06-2025, 03:30 AM
HKZ Bob's Avatar
Thanks I am looking tomorrow
Old 10-29-2025, 03:58 PM
