Best Factory Carpet Cleaner?
I am looking for the best way to clean factory carpet.
If the overall recommendation is that it is more hassle than elbow grease, then I will get another set. That said, what is the best option for aftermarket carpeting? Or is the best still factory? I have seen a lot of options out there: Car Bone, Sierra Madre, Newmark auto, etc. Lastly, what adhesive should be used to reattach the carpet to the floor? Thanks! |
PCA Member since 1988
I like to use a carpet shampoo/soap, but then I get the area pretty wet, and then use a shop vac to suck out the cleaner and water. Then rinse and repeat. Much like "steam cleaning" carpets in your house.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! |
