Loose connection wires in the frunk?
Hello,
I’m asking for a friend that has a 1987 911. Can someone determine what these 3 wires are/from and where they connect to? ![]() ![]() ![]() Thank you |
'87 Targa
I was going to answer this as a quick win. I have an '87 and it's an easy check. But...
The black female connector is power for the A/C Condenser fan. It has red power wire (vertical) brown ground (horizontal). Those match to one of the white male connectors in your pics. Here's the funky part. My '87 has a white w/green for the power. Now, I haven't run A/C for 30 years. So, I'm not sure that's correct. But, I also don't see a matching red / brown connector anywhere nearby. I don't know about the brown + yellow w/black. Mine is also orphaned there. ![]() |
I was in that area today and took pictures, but I have my battery maintainer in the way. I can take better pictures tomorrow, when I wrote the battery vent hose to atmosphere.
From what I recall, you’ve got the AC blower and the windshield washer pump there. ![]() |
That same factory diagram shows that the connector with yellow/back and brown wires is for the headlight washing system.
Gilles RoW 88 Carrera coupé |
Connector with red/white and brown wires could be for heated spray jets.
Thanks everyone for your help
'87 Targa
Thanks Giles. Very much appreciate the clarification.
