1977 911S
Disconnected Connectors in engine bay
I just took the black plastic cover off to inspect my fuse panel in the engine bay as I’m troubleshooting a heater blower motor issue. First time inspecting this part of my car and noticed two connectors that aren’t connected to anything. What am I missing?
One is a black 3 pin connector next to CDI box.
The other is a 1 pin connector that is transparent yellowish plastic close to the taillight assembly.
The car is not a sportomatic but for some reason there is a fuse in that location - any ideas?
Old 09-03-2025, 10:32 PM
proporsche's Avatar
The black connector was for external regulator -you have alternator on the engine now with internal regulator..the brown wire is for the safety switch at the air flow sensor..here is some reading
1977 2.7 engine wiring problems
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 09-03-2025, 11:10 PM
