993 964 Steering Rack rebuild - help!
Working on disassembling a steering rack for a 993. I can’t seem to get the input shaft to come out. I got everything else off and watched videos and people just pull it out. Mine is not budging. Is there some sort it trick I can try? Thanks!
Old 09-16-2025, 08:44 AM
Got it. Loosened it with tap tap on the side of the bearing then pull hard standing on it!
Old 09-16-2025, 10:32 AM
Make sure there aren't any grooves worn in the rack body from the teflon seals
Old 09-16-2025, 11:51 AM
