windshield antenna
When did Porsche first start putting an antenna in the windshield?
Was the 964 the first series with this? Or did some of the Carreras have it also?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Randy- I'm not sure when Porsche started antenna inlays, but my '88 has it. My 365 didn't, so it must be between '62 and '88.
Seriously, my antenna does not work very well at all.
Weaver '88 911 Targa '03 911 Turbo, X73 Susp. '13 Panamera GTS PCA member Central Indiana |
I believe it started in '84. I'm sure someone will correct me if I'm wrong.
'86 911 targa '04 MB 230K Sport (daily) |
My 87 used to have one, but the P O installed a fender mounted power antenna. Works great, but then I am usually listening to other sounds than the radio.
I think my windshield may have been replaced before and I see no embedded antenna. Are the windshield antennas visible or hidden?
-Steve '87 Carrera Targa |
Like Steeve, I'm pretty sure it started with the '84s - my '85 has one
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
i think the 916 had it in 1972.
73 914/4 2.0 sold 86 911 Carrera |
The window with the antenna costs around $600+ while the normal one costs a third of that.
For that reason I can understand people without comp changing their method of picking up radio waves. The wire is visible near the window gasket. |
I'm not a good shopper so I had a friend walk into the glass shop and discuss my situation with the boss.
"Hey Harold what's happening?" "I need a windshield for my friend, no tax and no bs. Do you understand?" "Sure, pick it up tomorrow." '88 new tinted Sigla w/antenna for $275
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
911 carrera 3.2 (1985)
My '85 carrera has it, but the reception is poor so I added an additional antenne under the dashboard and all is working fine now.
Kees. |
It started with the Carrera's 84.
Nick '85 Carrera |
Kees, can you be more specific about which under dash antenna you used? I'm about to replace my tired factory radio with an aftermarket and was thinking that an underdash unit of some kind would be the way to go. Looks like my windshield antenna wire is frayed where it disappears under the dash. Radio reception has never been that good in my car.
Thanks, Mark |
I got a new Sigla with antenna from my local "Autoglass" chain store for about $350. Install was about $50 and new OEM seal from Pelican about $50. Less that $500 for everything.
If your reception is bad, and you have an aftermarket radio, try bypassing the amplifier. My Alpine unit picks up stations 80 miles away easily with the windshield antenna connected directly to the radio.
John C 1988 911 Carrera coupe 2002 BMW 530 |
Re: antenna
Tim
1986 911 Cab 2008 Audi A6 |
911 541 011 03 windshield for 74-84, 911 541 011 04, 85-89. 1985 was the first yr 911 had embedded antenna, according to red book and part numbers.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
3.2 CAB is correct, 1985 was the first year for the windshield antenna.
Tim also makes an excellent point. most people with poor reception with the windshield antennas either have a bad antenna amplifier/booster, or it is simply disconnected. This is especially common on cars with after-market radios, as the installer usually disregards the extra"mystery black wire" instead of hooking it back up to switched 12v. |
My 84 "used" to have the antenna in the fender... -Jeff
Jeff |
Recreational User
I'm glad to see this thread! I've been wondering why my stock Blaupunkt wasn't receiving very well. The PO had the windshield replaced with a correct one for my '86 about a year before I bought it. After reading this, I suspect that the glass installer didn't hook the amp wire back up.
Where exactly is this mystery wire located? Can I get to it without too much trouble? |
So... I could put an '85 windshield into my '73 for less than $500 and have an antenna, right?
Does this have two small vertical wires that run up in the center? Or is that area unobscured? I'd have to add the antenna amplifier and then I could get decent reception w/o drilling holes in the fenders?
It's a really small wire, not like your typical radio wire. This wire, as stated above, goes to a booster, then out to a standard radio connector and into your radio. IIRC - the booster is in the trunk.
Nick '85 Carrera |
