Spring plate removal-'78 SC
Question for the group...
Car is a '78 SC that I've owned for 5 years. My spring plates do not have the height adjustment bolts, which tells me they're not original to the car. I purchased a set of the Elephant Racing adjustable spring plates and will install them tomorrow morning. My question it this...In addition to removing the sway bar and bottom shock mount, is it necessary to remove the calipers from the swing arm?
plates
Old 09-22-2025, 03:00 PM
No.
206 637 4071
Old 09-22-2025, 04:50 PM
Great news. Thanks.
Old 09-22-2025, 05:08 PM
My spring plates do not have the height adjustment bolts, which tells me they're not original to the car. ]
I don't believe OEM Spring Plates have height adjustment, Only toe and camber. The height is set indexing the torsion bar splines. The Elephant Racing do have a ride height adjustment.
Old 09-22-2025, 06:45 PM
Registered Minimalist
75 911s's Avatar
OEM plates would have the fine height adjustment bolts starting in 77 if not late 76. My 77 had them, my 75 did not.
So yeah, that's odd that someone would put older spring plates on an SC. You'll like the elephant plates. What bushings are you going with?
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 09-23-2025, 04:23 AM
Huh, I stand corrected. I don’t recall any on my ‘72, and not on my ‘83. What were the years? (‘76 thru ?)
Old 09-23-2025, 07:20 AM
safe's Avatar
I see that you have measured the angle? That is good, but do it with the lower right bolt removed because it probably rests on that and you will get a false reading.
Magnus
Old 09-23-2025, 07:37 AM
I just went with the stock rubber bushings.
Old 09-23-2025, 08:07 AM
Yeah, that angle measurement was put on there by a shop that previously did work on my car. I'll measure it again when I unbolt the shock and that lower right bolt. 24 degrees seems like the ride height would be pretty low.
Old 09-23-2025, 08:13 AM
my 76 "built in 75" does not have adjustable plates
Instagram.com/timofthevalley
Old 09-23-2025, 04:25 PM
