-   -   79 SC Plugged Rubber Pipe to Sensor Plate Boot (http://forums.pelicanparts.com/porsche-911-technical-forum/1184059-79-sc-plugged-rubber-pipe-sensor-plate-boot.html)
Jaymanbikes13 09-23-2025 06:10 AM
I have a California Spec. 79SC with EGR. The rubber pipe that connects the Aux. Air Slider was plugged at the Sensor Plate Boot. The replacement boot I am installing is also plugged but can be opened. My question is why would this line be plugged? See pics. Thanks!
http://forums.pelicanparts.com/uploa...1758632847.jpg
http://forums.pelicanparts.com/uploa...1758632871.jpg
Jaymanbikes13 09-24-2025 07:46 AM
I believe I have determine why it was plugged. This Aux Air Valve didn’t test good http://forums.pelicanparts.com/uploa...1758725171.jpg
Hokie6 09-25-2025 08:11 AM
How did you test it? The AAV is open until the engine starts, and vacuum is present. It then closes so air doesn't pass through it when running.
Jaymanbikes13 09-27-2025 07:39 PM
https://youtu.be/kSuNKcmwcKg?si=z1lY0Kp988LbovoF
