-   -   sunroof rattle when open (http://forums.pelicanparts.com/porsche-911-technical-forum/1184114-sunroof-rattle-when-open.html)
jgurnari 09-24-2025 10:28 AM
I had my sunroof out to deal
with a broken bracket, even before the fix I had a rattle from the sunroof when it’s open, either fully or partially open.
I am familiar with the height adjustments, four (2 on each side) on the front of the sunroof panel under the headliner and the 2 height adjustments on the brackets (1 on each side) on the sliders.. could an adjustment at those adjustable spots help stop the rattle.
The sunroof does have wiggle
room when i pull up and down on it with the roof slightly open.
Am
i missing glue-on sound pads?
acj47 09-24-2025 06:50 PM
have you checked if the plastic sliders are worn out? one of my was basically gone and rubbing on metal (red arrow) which allowed it more play since it could move vertically.
http://forums.pelicanparts.com/uploa...1758765014.jpg
jgurnari 09-24-2025 07:10 PM
i’ll check it. thanks
