down shift keeps gringing into reverse gear
All of a sudden, when i downshift from 5th to 4th it grinds into reverse gear...its getting harder to avoid.
Prior, when downshifting from 5th it effortlessly passed reverse and slid smoothly to 4th. Now I make an extra effort to avoid reverse but pulling the stick down and left, What could have possibly changed? Could it be the coupler has slipped? Is there a safety mechanism out of place?...No issue with shifting into gears. reverse for me is to the right and down...915 |
Take the shifter out and check the bushing where it pokes into the rod. They crumble after a while
As Porsche930dude says, check all bushings, replace as needed (our host sells them) and consider a Karsten Spring as well as the Ultimate Shift Rod bushing as part of your R&R process (search the forum for info on those and how/where to purchase).
makes sense.. but is it possible the coupler
adjustment might work? |
Stock shifter? Reverse lock out not functioning?
Pull boot and static check the shift action, then adjust accordingly so spring on lockout cam engages to prevent going into R. Somehow you’re missing the lockout function and it’s usually a shift rod not doing the job due to excess slop or travel limitation. Maybe shift assembly needs some cleaning and grease? Of course going from 5 to 4… R won’t (or most likely not) be avoided on a power slam if a hair out of adjustment. I’m with P930Dude & Winter - I replaced ALL bushings - including the shifter cup…and added the spring, which once you get used to the feel of it, there’s a sure snap over to the 3-4 plane. It’s not a cure-all but a maintenance necessity to check replace these plastic nylon bushes…after 40 yrs even the coupler of still original. You don’t want to adjust coupler to the tolerances worn bushing or an old worn coupler. Though minuscule, the adjustment could affect the shifting later on or might still not better than before. 2¢ |
changed coupler bushings
I changed the coupler bushings and the shift bushings 5 to 6 years ago.
Hope its an adjustment on the coupler, although it shift 1 thur 4 fine...5 and reverse are more difficult to "find"... Hope ITS NOT the lockout, Such a pain getting the boot off...having to take out the console. what is a pain QUOTE=EC900;12540835]Stock shifter? Reverse lock out not functioning? Pull boot and static check the shift action, then adjust accordingly so spring on lockout cam engages to prevent going into R. Somehow you’re missing the lockout function and it’s usually a shift rod not doing the job due to excess slop or travel limitation. Maybe shift assembly needs some cleaning and grease? Of course going from 5 to 4… R won’t (or most likely not) be avoided on a power slam if a hair out of adjustment. I’m with P930Dude & Winter - I replaced ALL bushings - including the shifter cup…and added the spring, which once you get used to the feel of it, there’s a sure snap over to the 3-4 plane. It’s not a cure-all but a maintenance necessity to check replace these plastic nylon bushes…after 40 yrs even the coupler of still original. You don’t want to adjust coupler to the tolerances worn bushing or an old worn coupler. Though minuscule, the adjustment could affect the shifting later on or might still not better than before. 2¢[/QUOTE] |
jgurnari, Unfortunately with the console it’s a bit more work. I don’t have one.
The forward motion into 5th, the shift rod may not be forward enough to engage lockout cam …now it’s why is that occurring - Not sure if coupler adjust would be effective if bushings are toast. Short term maybe, but every hair of adjustment to get it right (or not) may take as long as a console removal. |
here is how it is adjusted -hope it helps
https://www.youtube.com/watch?v=b3nPONBAaZM |
familiar with the adjustment video, did that only a few months ago.. that’s the reason I think it might be the issue, could have slipped a little.
I will try making g the adjustment again.. if it doesn’t help, i will get into the console. brutal! |
For the shifter adjustment, I use a bungee cord to hold the shifter over to the driver's side and then push the shift coupler over to the passenger side with one finger as I tighten the bolt. The forward and backwards part is indeed best to have the lever in the middle of the throw. http://forums.pelicanparts.com/uploa...1759353385.JPG http://forums.pelicanparts.com/uploa...1759353385.JPG http://forums.pelicanparts.com/uploa...1759353385.JPG |
i’m confused!
i read something about removing the shift knob .. you also mentioned pulling it off, why? what is the purpose of removing the shift knob? Are you able to get the boot off by simply removing the shift knob? The console has to come out regardless, no?. UNLESS you are able to remove the boot without removing the console.. My boot is pinned under the console …there is no way to remove it with the console attached to the floor. Am i missing something that would make things easier?… like removing the knob and getting the boot off?
I don’t have a console, and I don’t know if you also have a gaiter that covers the rubber boot like the one pictured, and if you can pull it up enough and out of the way, tape it to hold in place or invert the rubber boot and it will stay put. Then working the shifter into 5th-4th to look down into the shifter housing to check the R lockout cam action.
But as you said, you had made an earlier adjustment and the lines/reference marks may be off a hair or clamp wasn’t tight enough. See below as to why I’m an advocate for bushing inspection - my PO had coupler replaced (for same issue of missing a gear I believe) and tech adjusted but never checked the bushings that’s attributable to my excess slop and occasional 5/4 gear crunch. (45 yrs & 200k miles) http://forums.pelicanparts.com/uploa...1759363265.jpg Note the new Pelican JPNovak bushing length vs OEM less the broken half + more meat less chance of wobble … http://forums.pelicanparts.com/uploa...1759363381.jpg |
ok thanks. do you happen to have a photo or video of the lockout cam and how it operates?
i’ve got an ‘85 w/313k |
The cam: http://forums.pelicanparts.com/uploads26/85278CEC_AEAA_4537_AAF8_DEC4BF4E8ABE16115214321611 617332.jpg Possibly helpful info within: https://forums.pelicanparts.com/porsche-911-technical-forum/1084217-reverse-lockout.html |
Another issue could be the cast shift cup holder is becoming loose on the shift rod. Check to see it is tight. A couple of spot welds (everything in place) to hold the cup to the rod is doable.
What happening now!
I adjusted the coupler, it does not grind into 4th when downshifting BUT NOW, with the slightest touch it will pop out of 5th gear and go into the neutral channel but still be in gear (5th) but moves side to side as if its in neutral. It is not sloppy in any other gear. What adjustment would fix that?...is it the shaft not being in or out too far within the coupler? |
It almost looks like the receiving piece for your teflon socket is loose on the shift rod-the red circle There is a screw on the other side to hold it in place =could be loose
Ivan http://forums.pelicanparts.com/uploa...1759431233.jpg |
http://forums.pelicanparts.com/uploa...1759431456.jpg You can see the top of the leather gator was worn and the color was gone. I wanted to get it off to repair the leather, and dye it back to the proper Burgundy color. Of course I replaced all the bushings, and put it all back. And the photo above shows my 3D printed water bottle holder. It is insulated with spray foam, and holds the bottle perfectly and I can get a sip of water while driving without taking my eyes off the road. One of my great inventions for my car. I sure did not need that space for cassette storage! |
not my shifter
that picture is not my car
I have done everything (rebuilt trans, shift rod bushing, factory short shift, ...) but I still can't get the trans into first easily when stopped or into reverse unless I depress the clutch several times. I have constant problems with the 5th to 4th shift hitting reverse. It can't be done quickly unless you wait a second before you engage 4th.
jgurnari - it could be a fore/aft adjustment. Shift fork issue (?) low on gear oil (?) other possibilities coming up with a just a tired 915 that hasn’t seen a 100k rebuild or a basic fluid replacement.
Most unfortunate exasperation to get a different adjustment result. Are your reference marks lining up and remaining after those test drives? Are the older ref. marks still there to go back replicate the early issue? I find adjusting the coupler a pain, removing the pass. seat made more room to eyeball marks and easier to access shifter positions while watching coupler. But…. I say remove that console this weekend and dig deeper, inspect/order Pelican parts, then next weekend replace, adjust, and ‘banish the console’ next weekend. :) Once you get it off you’ll better see what action is going on and where the adjustments are affected. I think Porsche aficionado Jerry Seinfeld may have once said; ”That’s the deal with those air cooled 911 consoles. They cause more consolation than comfort”. :) Here’s another good video on adjustment and features the 5th/4th/R lockout, around the 7:00 minute mark, but the whole video by him (at Garage Time) is well spoken and produced reference….. https://www.youtube.com/watch?v=tEdOeHUYjU0 |
this picture is to quide you where your problem could be-i did not say it is your 911.. here is another pic of the cup with the screw-which could be loose on the shift rod.. Ivan http://forums.pelicanparts.com/uploa...1759437497.jpg |
Took a WHILE, A LOT OF ADJUSTING IN A CRAMPED SPACE but an adjustment did the trick! Thanks for the help
Actually, I still have the same issue. Thought I was hitting every gear but when I shift to 5th, it feels like its 5th gear postion but it is 3rd again...goes to reverse, and all other gears but not 5th. Brutal!
jgurnari - SmileWavy For your consideration:
If your shift rod bushing is broken and the shift rod is flopping around, each time you make an adjustment you’re not actually getting it right because without a shift rod bushing for stability, your going to be off by appx. 3mm (?)…the side wall thickness of that bushing. Now transfer that movement down the length of the shift rod to the coupler and the adjustment becomes a probably another 2mm larger. And this also doesn’t account for if the ball cup socket bushing is also deteriorated and maybe the bushings in the coupler. The effect of the shift rod movement is that like a pendulum, though not as extreme. Fixed on one end (at shifter) it subtlety sways or offsets at the other end at coupler (which has its own natural wiggle room) and because nothing is holding the shift rod steady during the adjustment (maybe besides a hand to tight set screws). Without the stability of a shift rod bushing.. and if the shift rod is leaning and held to the right side (or left) inside the bushing bracket, that adjustment could still would be incorrect, same if you’re trying to center the shifter in Neutral position w/o a bushing, it’s not correct and putting the adjustment off position. Given the fact even with all new bushings along the shift process, adjusting is still tedious to get it right. The older I get the smaller the 911 interior gets. Pulling the seat (and your console :).…will make a big difference. For what it’s worth, I needed a stubby end allen wrench (4mm?) to remove set screw on the shifter ball cup fitting which is indexed with slot on the shift rod (see proporshe photo) plus it was rusted tight on the shift rod. Something to prep for with PB Blaster. http://forums.pelicanparts.com/uploa...1759603845.jpg http://forums.pelicanparts.com/uploa...1759604006.jpg |
Got it!
Thankfully I did not have to take out the console!...I finally got the right setting on the linkage...and hopefully it stays for a while and it does not slip.
The clamps also go bad and slip
Wevo has a nice upgrade http://forums.pelicanparts.com/uploa...1759624880.jpg |
Well, i got is back to shifting into every gear... BUT back to square one...it still shifts to Reverse when downshifting from 5th to 4th.
Will take your advice...thanks all! |
Ivan |
