My first 1980SC Targa
I wanna start my introducing myself. My name is Edgar and this is my first 911. Owned for a year and 4 months now, i picked this up from a customer at work. Its been a California car its whole life and always garaged.
Long story short, his brother passed away and it sat in the garage for 2 years. Customer said the engine/trans was making noise and was assuming it would need a rebuild. He wouldn't let me start it to check oil level or hear it, so i had to buy it as a "roller". After 2 weeks of going back and forward i said F it and bought it as the price was too good. Called the tow truck driver to drop it off at the shop i work at and got started on it. Started by draining the oil. Dry, nothing came out. So put oil in it, new oil filter. Next was the transmission, that had oil in it but was very dirty and low. Put new Swepco 201 and gave it a good flush. New spark plugs and wires and it was time to try to start it up. Car cranked but no start for a good minute of trying. After the 3rd time, it started! If you wish to see more pictures, my IG is s2k_9k. ![]() ![]() ![]()
Fast forward to today and alot has been done to the car. From full suspension components to smaller items.
Rebel racing spring plates control arm bushings and ball joints swaybar bushings turbo tie rods B6 shocks F/R Lowered to euro height, aligned and corner balanced rear axles motor mounts and transmission mount BBS E87 wheels OEM Carrera Whale Tail RUF front valance SSI heat exchangers with SSI GT3 center exit exhaust and so much more. At this point im just enjoying the car and driving it as much as i can |
Tastefully modded! Love those BBS wheels.
1984 911 Targa 1980 Toyota Pickup |
Very cool. Im on this journey myself with a 79 sc.
Question for you - with SSI it is obviously not CA smog legal. What is your plan with smog checks? Are you going to swap back to stock exhaust every 2 years? Also - what is the benefit for the historic vehicle plate over a standard plate?
2021 C2S Manual 1979 911sc Targa |
Ruf front valance and BBs wheels , killer combo !!
![]() plate has no benefit, just always liked them so i chose to get one for it. |
Technically I think with Historic plate limits your mileage and when/where you can drive - no daily driver, only to Shows/Events....
1986 Carrera 3.2 Coupe in Grand Prix White IG: @c.cal.porsche |
PCA Member since 1988
Nice looking ride.
Odd that the engine had no oil in it. That's almost certainly why the seller would not let you start it. He probably knows something you don't ("making noise... assume it needs a rebuild"). Anyway, it sounds like you got it running with no nasty noises, so drive on. If you haven't done this already, I also recommend that you pour a bottle of Techron Concentrate in the tank with fresh gas and drive it hard to make sure the fuel injection is clean. And set aside a reserve fund in case it does start making expensive noises.
1973.5 911T with RoW 1980 SC CIS stroked to 3.2, 10:1 Mahle Sport p/c's, TBC exhaust ports, M1 cams, SSI's. RSR bushings & adj spring plates, Koni Sports, 21/26mm T-bars, stock swaybars, 16x7 Fuchs w Michelin Pilot Sport A/S 3+, 205/55-16 at all 4 corners. Cars are for driving. If you want art, get something you can hang on the wall! Last edited by PeteKz; 10-08-2025 at 12:22 PM.. |
Very nice! Congratulations!
Keith 1978 911SC Dirty Penny |
My favorite BBS wheels.
That is correct. I already had it insured through hagerty so milage was already limited. Between this and my s2000, i dont get to drive them much so i figured id just get the plate. I do drive it for fun not just shows/events too
Thank you! Quote:
My favorite too! wasnt too sure about them in the beginning but have grown on me alot. |
