steven c's Avatar
76 911 wiring harness question
My friend got a 76 and we are trying to figure where the wiring harness thru the interior is supposed to be. The only pics I have for now is of the rear seat exit which doesn't seem correct...but I can't find a good thread for this question.
Thanks for any help.
91 964 turbo
81 ROW 911SC
11 997.2
Old 11-14-2025, 08:55 AM
Kroon Wire Harnesses
All wiring from front to rear runs through the center tunnel, this can be the tunnelharness, battery cable, but also wiring for the AC clutch and rear wiper.
Specialized in Classic Porsche electrics
www.kroonwireharnesses.com
Check also our Facebookpage: https://www.facebook.com/kroon.wireharnesses
Old 11-14-2025, 10:53 AM
steven c's Avatar
Okay, so do you know what goes thru the hole in my picture? I have seen in other threads wiring going thru it??
91 964 turbo
81 ROW 911SC
11 997.2
Old 11-14-2025, 11:14 AM
I have a 76 coupe and no grommet in that location. My rear panel appears to be a little different shape. Is his a Targa? If so, perhaps it’s the defrost wiring grommet? Just a guess.
76 911S Signature Edition w/ 3.2
Old 11-14-2025, 12:21 PM
steven c's Avatar
No, this is a coupe. Okay, it was just one or two pics that I saw wiring in a hole there but it made no sense to me since how do you get the upholstery down over it.
91 964 turbo
81 ROW 911SC
11 997.2
Old 11-14-2025, 12:26 PM
Registered Minimalist
75 911s's Avatar
The main harness runs through the tunnel and out by the passenger side, it curves up under the torsion bar tube and then behind the firewall and across to the rear fuse panel. There's nothing there on the stock car to my knowledge. The rear defrost comes from a tiny hole at the bottom of the drivers side rear window and threads over to the fuse panel.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 11-14-2025, 03:41 PM
That appears to be added by a PO who also resprayed the panel as that is not a stock finish either.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 11-14-2025, 03:48 PM
